Hello Guest it is June 10, 2026, 04:46:11 PM
Author Topic: Manual button for auto zero  (Read 34519 times)
Re: Manual button for auto zero
« Reply #10 on: April 14, 2011, 04:14:40 PM »
But can't you activate an onscreen button that calls a macro? Or that doesn't work?
Offline Greolt
  •  956 956
« Reply #11 on: April 14, 2011, 04:33:25 PM »
I don't believe that you can.  Could be wrong.
It was a long time ago that I looked into this.
Greg
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #12 on: April 15, 2011, 03:18:33 AM »
I guess I was just making the point that as far as Duc748's particular requirement here, there's no need for any macros (or macropump) at all in the first place, so how to fire one is not really an issue.
However, if you DID want to use a trigger macro that handled multiple triggers, then it just requires a "select" statement so is not really that comlex.
Anyway - JMHO
Ian
Offline Greolt
  •  956 956
« Reply #13 on: April 15, 2011, 04:56:58 AM »
I think the question was about triggering an auto tool zero routine, which is a macro.
Hi Greg,
I am running a twin Z axis machine (Z and A axis) with external zero buttons for both axis, can you please advise on what additional code I need to add to the macropump?
I have 2 separate Macros M615 and M616 one for each axis in the macro folder but unsure regarding the macro pump.
And yes I am sure with a bit of clever macro writing it could all be handled in the trigger macro.
However Rick has been using this macropump/brain combination method for a while and asked how he could extend it to cover dual Z axis.  Hence my reply.
Greg
« Reply #14 on: April 16, 2011, 02:21:22 AM »
Well thanks for all the input,
I have implemented this as Gregs method based on the fact that the Brain has the safety feature of holding the button for 2 seconds for activation..I think this is important as people do push buttons..ah whats this for..you get my meaning.
The trigger macro does interest me too..is it possible to have the safety feature built into this method?
thanks again
Rick
Offline stirling
  •  2,188 2,188
  • UK
« Reply #15 on: April 16, 2011, 05:26:08 AM »
Hi Rick - can you clarify whether you're talking about an "auto tool zero" or just about zeroing the axis as per the standard Z and A zero buttons please?
Ian
« Reply #16 on: April 16, 2011, 12:59:52 PM »
Hi Ian,
The machine is configured as auto zero tool buttons with touch off plate.
Rick
Offline stirling
  •  2,188 2,188
  • UK
« Reply #17 on: April 17, 2011, 12:24:44 PM »
OK Rick and Greg - I misunderstood the requirement - Mea culpa.
However Rick if you do want to have a go via a trigger macro then yes you should be able to code in any safety features you like. See http://www.machsupport.com/forum/index.php/topic,15120.msg101160.html#msg101160 where if for example you put a "sleep 1000" as the first line of the example code, it would test whether you held the button that fired the trigger for more than a second before doing whatever.
Ian
Offline Greolt
  •  956 956
« Reply #18 on: April 17, 2011, 04:44:58 PM »
Ian
The advantage of using a brain is the timer safety.   If the switch/button is held for less than the specified time (2 sec) then nothing happens.
Can you give us an example of how to do this in the trigger macro.  It would be very handy to know how this is done.
Would it be an if/then with a pause and recheck input?
Greg
« Reply #19 on: April 17, 2011, 04:50:31 PM »
Greg,
Ive been testing my setup today, I noticed that nothing happens for 2 seconds as my input into the Brain, but if I try the auto zero again it starts as soon as the button is pressed and no 2 second delay.
You have any idea what ive done wrong?
Rick
