Hello Guest it is June 11, 2026, 02:41:15 PM
Poll
painting
pait
1 (100%)
1
0 (0%)
1
0 (0%)
Total Members Voted: 1
Voting closed: October 11, 2010, 05:40:15 AM
Author Topic: Paint  (Read 9274 times)
Paint
« on: October 01, 2010, 05:40:15 AM »
Hello
I want ask to move mach 3 with joystick like robot hand.
My question are : I want to install joystick with paint pistol and to record moving to G-Code.And after that i can play again from my record and the hand repeat my action
Re: Paint
« Reply #1 on: October 01, 2010, 08:02:56 AM »
The Jog to Code plugin may be what you are wanting, its available from the Downloads tab then Plugins.
Re: Paint
« Reply #2 on: October 01, 2010, 03:50:54 PM »
I dont understand .
How can i recording moves on joystick.like G-code.
And afrer that to play .
I can connect joictik to much 3 but how to recording action from my hand(joystick).And afterthat to play
Re: Paint
« Reply #3 on: October 01, 2010, 04:46:04 PM »
As i understand it, you need to record and playback the movement of a spraygun for repetitive painting - so you need very accurate recording of multiple axes at once with highly variable feedrates. would jog-to-code support this?
How big and how complicated is your job? a shoe box will be easier than a motorbike frame.
Re: Paint
« Reply #4 on: October 02, 2010, 12:37:43 AM »
Wood box for loadspeacers.I think this is must be made from stepper motors. And 4 or 5 axis machine.
Re: Paint
« Reply #5 on: October 02, 2010, 05:21:39 PM »
You may want to have a look at CopyCat. You move the axis using a web camera ( dosen't have to be a camera ). It tracks your moves and generates the gcode. Additionaly there are edge and center finding  routines built into it. You can find a wirte up on how to use it in the Members Docs.
