Mach Discussion => General Mach Discussion => Topic started by: bpetkov on October 01, 2010, 06:40:15 AM
Hello
I want ask to move mach 3 with joystick like robot hand.
My question are : I want to install joystick with paint pistol and to record moving to G-Code.And after that i can play again from my record and the hand repeat my action
The Jog to Code plugin may be what you are wanting, its available from the Downloads tab then Plugins.
I dont understand .
How can i recording moves on joystick.like G-code.
And afrer that to play .
I can connect joictik to much 3 but how to recording action from my hand(joystick).And afterthat to play
As i understand it, you need to record and playback the movement of a spraygun for repetitive painting - so you need very accurate recording of multiple axes at once with highly variable feedrates. would jog-to-code support this?
How big and how complicated is your job? a shoe box will be easier than a motorbike frame.
Wood box for loadspeacers.I think this is must be made from stepper motors. And 4 or 5 axis machine.
You may want to have a look at CopyCat. You move the axis using a web camera ( dosen't have to be a camera ). It tracks your moves and generates the gcode. Additionaly there are edge and center finding routines built into it. You can find a wirte up on how to use it in the Members Docs.
