Hello
Guest
it is
June 10, 2026, 07:27:03 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
CamBam Gcode problems
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: CamBam Gcode problems (Read 19536 times)
Jeff_Birt
1,107
Re: CamBam Gcode problems
Reply #10 on:
September 16, 2010, 07:39:05 AM »
Also make sure you select the 'mach 3' post processor in CamBam. The generic one works 99% of the time, but the Mach one is fine tuned to play well with Mach's defaults.
Happy machining , Jeff Birt
Check out
www.soigeneris.com
ger21
6,295
Reply #11 on:
September 16, 2010, 10:40:06 AM »
I and J are the XY coordinates of the arc center. Absolute mode uses the exact coordinates. Incremental specifies the center relative to the start of the arc.
Jeff K
16
Reply #12 on:
September 16, 2010, 07:43:45 PM »
Thanks to all who responded. I still have a lot to learn, but I'm getting there. I appreciate all your help.
Best regards to all.
Jeff
Print
Pages:
1
2
Go Up
« previous
next »
