Hello Guest it is June 12, 2026, 05:28:50 AM
Author Topic: ReadMe file woes  (Read 49535 times)
Re: ReadMe file woes
« Reply #10 on: July 23, 2010, 10:13:57 AM »
Thanks Dave, the emailed version works just fine - all I've got to do now is read it and understand it before installing the screen set. Thanks for all your efforts, Mach is really a great tool.
Mike
« Reply #11 on: July 23, 2010, 10:14:06 AM »
BTW - I found a bug in the beta 2 readme file
I can already hear Karl now..... :(
The readme on the website didn't get the table of contents updated before I turned it into a PDF.
I've sent an updated pdf to Scott to replace the one on the web site.
The instruction info in the pdf will not change, just the TOC.
Mike: the one I emailed to you is already corrected.
www.CalypsoVentures.com
« Reply #12 on: July 24, 2010, 12:18:55 PM »
Another observation
  Dave I am trying to install the new screen today.  I downloaded the "readme file" and uploaded it to my iphone to take with me to the machine. It did not transfer to the Iphone.   So I download all the other documents (.pdf) from the Artsoft web site.  Guess what, all loaded into my I-Phone "Ebooks" reader with the exception of the MechStdMill_readme.  What are you using to generate the .pdf?  Maybe it is a non-standard .pdf generator.  It reads fine on my PC reader (adobe & Fix reader), but not the iphone.
  I am sorry this is not a solution to a problem, but it does give a little more input into what may be the problem.
  I am going to get this installed !!!
  If it weren't for the !!@!@!@@ readme file, I'd have this thing running by now.
Karl
« Reply #13 on: July 24, 2010, 12:31:13 PM »
I use the real Adobe Acrobat package to create the PDF files.
I have this ancient device - I think they call it a printer.... It generates these light weight layers of pressed wood with ink on top - real handy stuff.  ;D
« Reply #14 on: July 24, 2010, 02:00:28 PM »
OK Dave
   I'm installing and I am on page 13 of the "readme".  I am confused by the 2 options.  If I understand it properly if I use option 1, I must enter all my ports and pins data, motor tuning and etc, manually.  Is this correct?
  When it came in the estop was not configured and I assigned tehn to a wrong pin and the entire mach3 hung.  I had to do a 3 fingered salute to regain the computer.
   Next a rand Mach again this time I configured the estop correctly and the scrolling message area said to "hit the "reset" button.  There is no longer a "reset" button on this screen.  The message needs to be change to the "Mach ready" button.
Karl
« Reply #15 on: July 24, 2010, 02:35:46 PM »
Karl,
[Karl]   I'm installing and I am on page 13 of the "readme".  I am confused by the 2 options.  If I understand it properly if I use option 1, I must enter all my ports and pins data, motor tuning and etc, manually.  Is this correct?
[DB]: correct. The desire to avoid having to enter ports& pins again is why many use option 2. Both options get you to the desired end result. unfortunately, there is not an easy way to automate this - it would require that I write a program to open a profile XML and go in and change settings in the XML. Since the XML contents are not supported or documented interfaces for mach, that would not be a good thing to do - so the user gets stuck doing some hand configuration on first install.
MSM mster profile + Ports & pins -> desired end result
and
user profile (already with ports & pins etc) + MSM options -> desired end result.
[Karl]   Next a rand Mach again this time I configured the estop correctly and the scrolling message area said to "hit the "reset" button.  There is no longer a "reset" button on this screen.  The message needs to be change to the "Mach ready" button.
[DB]: sigh. That's my fault really. The "reset" message comes from inside mach - mach assumes the button is called "reset". For various reasons I used ready/not ready. I suppose that if enough people push on me I could change "ready" to "reset".
But I also had early feedback that "reset" was ambiguous language. For some things,  when they running and you reset them, they stop. Other devices in the world act the opposite, you have to reset them to make then ready to run.
« Last Edit: July 24, 2010, 02:39:57 PM by DaveCVI »
« Reply #16 on: July 24, 2010, 03:37:31 PM »
   I agree the ready/not ready is preferable.  We just need to get Brian to change the error messages or allow you to.
   I am a little uneasy manually re-entering all my ports & pins info.  I just hope I got them all.  How much of "general config" also has to be entered manually?  I think you might want to make this a little clearer in the "readme".  Maybe I'd better read the rest of the "readme"
  I had trouble with the MDI window.  I could not get the machine to move.  Then I realized the error message window was at the top of the screen and the MDI in the lower screen area and I missed the message.  I think the message area needs to be more pronounced (blink or change colors?).  I gave it a G1 command without a Feed rate.  Seems to me this should not have been a error but maybe it is to Brian.  In my other machines, it defaults to the last feed specified or a default value.  I know, that's not your problem.
   A further point of information.  I just saved the "User's Manual" to the I phone and now the ReadMe file is also there.  I can not explain it, do you suppose I'm getting old and I just missed it the first time?  Naw, it's a computer "feature", I'm sure.
Karl
« Reply #17 on: July 24, 2010, 05:40:51 PM »
You shouldn't need a feedrate when doing a G1 move in MDI. It should work as you described, using the last commanded feedrate. I haven't tried the new version, but the old ones work fine without a feedrate. Are you sure the problem isn't something else? Or was the MDI functionality changed? I hope not, as it would be a PITA to have to enter a feedrate every time.
« Reply #18 on: July 24, 2010, 05:44:42 PM »
HI,
The modal relationships between movement commands and feedrates is part of how GCode is defined.
MDI has not changed  - It's a control Mach implements - what is does is not modifiable from a screen set.
G1 w/o FR works fine for me - behaves as it always has in prior version of Mach.
« Last Edit: July 24, 2010, 05:48:01 PM by DaveCVI »
