Hello Guest it is June 11, 2026, 05:46:29 AM
Author Topic: Setting Z axis height  (Read 9520 times)
« on: July 06, 2010, 08:21:53 PM »
I am in the infancy of starting up my CNC router and have another basic question.
How do I tell Mach where the top edge of my piece to cut is located? Is there an offset you enter first before running one of the example G code files (such as the Road Runner?
Castle Works
Re: Setting Z axis height
« Reply #1 on: July 06, 2010, 09:16:01 PM »
Jog the tool to the top of the part, and zero the Z axis.
« Reply #2 on: July 06, 2010, 09:23:03 PM »
Well that is too simple  :D
Thanks for pointing out the obvious (I am learning lots as I go)
  •  9,356 9,356
« Reply #3 on: July 07, 2010, 04:09:03 AM »
A little further down the line you may want to implement the Auto Tool Zero function using a touch plate.
A search of the forum for 'touch plate' should bring up all the details of what others have done here. It is a worthwhile addition to any machine which I would not be without now.
