May 26, 2012, 06:51:08 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Z axis G1 moves get shorter with reduced feed rate
Pages: « 1 2   Go Down
Print
Author Topic: Z axis G1 moves get shorter with reduced feed rate  (Read 871 times)
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #10 on: June 18, 2010, 04:42:47 PM »
Sounds like something is tight and the slow speed is causing lost steps.
Global Moderator
Offline Offline
View Profile
« Reply #11 on: June 18, 2010, 07:31:55 PM »
Tend to agree with Gerry and Hood that it is mechanicaly related.
stirling
Global Moderator
Offline Offline
UK
View Profile WWW
« Reply #12 on: June 19, 2010, 03:45:24 AM »
what microstepping value are your drivers set to?
Ian
airnocker
Active Member
Offline Offline
View Profile
« Reply #13 on: June 24, 2010, 03:40:37 PM »
Just a thought, did you run "Drive Test" on the 2nd PC after Mach3 installed and rebooted?
airnocker
spannerman
Active Member
Offline Offline
View Profile
« Reply #14 on: July 06, 2010, 02:38:54 PM »
SOLVED!
You guys were quite correct, it was mechanical. I found some tightness in the new leadscrew.
I've cured that and also upped the gear ratio on the Z axis.
Thanks for all your help.
Pages: « 1 2   Go Up
Print
Jump to:
