Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 26, 2012, 03:04:01 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Mayday, mayday, mayday: Steppers thumping and banging and losing steps
Pages:
1
Go Down
« previous
next »
Author
Topic: Mayday, mayday, mayday: Steppers thumping and banging and losing steps (Read 629 times)
BluePinnacle
Active Member
Offline
on:
May 24, 2010, 05:41:04 AM »
Trouble at t'mill! I replaced the computer after the frost killed the old one off, and now it really won't play.
It's a faster computer (1.5ghz Athlon over the 900mhz Pentium) and when jogging, with a 45khz kernel, it will easily drive at 2000 mm/min plus. However when executing G-code commands the buffer instantly exceeds 100% and the pulse train goes nuts, causing severe amounts of lost steps. I'm down to about 1200 mm/minute maximum now, and when executing a long, slow helical move it still loses steps, and the steppers thump and stumble.
Any common reasons why this would happen? I'm going to be in trouble if I can't get the beast dancing nicely, so any help offered would be sincerely appreciated. Thanks in advance
Active Member
Online
Carnoustie, Scotland
Re: Mayday, mayday, mayday: Steppers thumping and banging and losing steps
Reply #1 on:
May 24, 2010, 06:31:37 AM »
Fresh install of the operating system is best, if it is, then possibly the optimisation steps will help. Another couple of things, if its a low voltage parallel port you may need a buffered breakout board (may already have that?) also you may be needing to change the active state for Step/Dir pins.
BluePinnacle
Active Member
Offline
Reply #2 on:
May 24, 2010, 07:37:02 AM »
Hi Hood, thanks for the suggestions.
Sorted it ... it was a fresh install, and the parallel boards i was using beforehand (MosChip items, very robust).
the problem turned out to be USB things again - I could make it crash by scooting the mouse about. It seems WXP prioritises USB demands over anything else, legacy ports in particular, and therefore any USB activity (even routine polling for changes) causes a machine crash.
Solution: disable all USB systems and use a PS2 mouse and kb. While I was there I stripped out the soundcard, network card and usb PCI card. This releases a lot of memory and lowers the amount of possible interruptions. That done, it now interpolates helical paths at 1800 mm/min with only 24% buffer load. I think it could go a lot faster
this USB thing has been a persistent problem ... any ways round it? occasionally I need to get things on or off the mill.
Active Member
Online
Reply #3 on:
May 24, 2010, 08:20:20 AM »
Afraid I have never had any USB issues on any of my machines but used wired stuff as I dont trust wireless stuff.
BluePinnacle
Active Member
Offline
Reply #4 on:
May 24, 2010, 10:14:50 AM »
rapids now up to 2000 mm/minute with no lost steps. No wireless parts involved. Still stumped.
Active Member
Online
Reply #5 on:
May 24, 2010, 01:07:15 PM »
Ah sorry saw you mentioning wireless in another post so just assumed.
BR549
Active Member
Offline
Reply #6 on:
May 24, 2010, 05:31:40 PM »
Blue, ran into some of the same things. Went to a PS2 keyboard and mouse. That fixed that part
To avoid other problems with the USB thumdrive for program tranfer, I never access the thumbdrive while in mach . If I need to load something I always leave mach then do what I need to do Close down the drive and then come back.
So far with those restrictions NO problems here.
I have a friend that uses a thumbdrive to run programs "from the usb thumbdrive" without a problem .
I can 't give you an answer as to why yet but I am still lookin.
Hope that helps
simpson36
Active Member
Offline
Reply #7 on:
May 25, 2010, 09:02:40 AM »
Look for shared interrupts between the USB and IDE, Graphics card, SCSI, etc.
I run g-code off a thumb drive no problem and have a USB mouse as well.
BluePinnacle
Active Member
Offline
Reply #8 on:
May 29, 2010, 12:52:24 PM »
that may be an issue. I never got to working out how interrupt requests actually worked. Presumably sharing an IRQ number would cause problems, but is there a way to pioritise interrupt requests, one over another - ie set the paralell cards to one number, and the USB ports to another (lower?) figure?
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
