Hello Guest it is June 12, 2026, 02:20:05 AM
Author Topic: circular interpolation  (Read 9798 times)
« on: April 10, 2010, 04:29:45 AM »
can anyone confirm that mach 3 will recognise the K variable in a G02 or G03 command when machining curves that run on XZ or YZ plane? Also when used in conjuction with G18 G19
the controller on my machine unfortunately will not, so i am considering converting to mach 3!
many thanks
Re: circular interpolation
« Reply #1 on: April 10, 2010, 05:57:35 AM »
pmessilver,
You may want to have a look at Mach3 Turn Arc Motion writeup which can be found in  MEMBERS DOCS.
It covers a lot of info and gives explaination / comparison of using G02/G03 for G18. There are files which you can try out and  play with.
FWIW,
« Last Edit: April 10, 2010, 06:00:30 AM by RICH »
« Reply #2 on: April 10, 2010, 07:23:03 AM »
I answered you on CNC Zone, but again, the answer is yes.
