Hello Guest it is November 13, 2026, 04:08:19 PM
Author Topic: Properly doing "Run Frome Here"  (Read 77059 times)
Re: Properly doing "Run Frome Here"
« Reply #10 on: June 29, 2010, 01:54:36 AM »
There is an option on General Config page called Ignore  M calls while Loading I am not sure if that will help when doing a Run From Here or not but its worth a try.
The other option you may have is to use the Set Next Line option rather than RFH, never used it so not sure if it will do as you wish, again worth a try.
« Reply #11 on: June 29, 2010, 03:02:28 AM »
i have problem with RFH
i think in plasma dont work
for example in this code:
N0100 G00 Z50.0000
N0110 X54.5560 Y43.6976
N0120 G31 Z -100 F500.0
N0130 G92 Z0.0
N0140 G00 Z0.0000
N0150 G92 Z0.0
N0160 G00 X54.5560 Y43.6976 Z5.0000
N0170 M03
N0180 G01 Z2.0000 F500
N0190 X56.6592 Y42.9879
N0200 X61.0873 Y42.8287
N0210 Y41.0483
N0220 X32.7073
N0230 Y42.8287
N0240 X37.3161 Y43.0319
N0250 X38.5330 Y43.3942
N0260 X40.4880 Y44.6611
N0270 X41.5513 Y46.2541
N0280 X42.0049 Y48.4512
N0290 X42.2073 Y52.7383
N0300 X42.1246 Y98.4651
N0310 X41.7569 Y101.3149
N0320 X41.0934 Y103.1154
N0330 X39.6993 Y104.4128
N0340 X37.6922 Y105.2646
N0350 X35.1942 Y105.5483
N0360 X32.7073
N0370 Y107.3283
N0380 X51.5873
N0390 X51.6252 Y50.7880
N0400 X51.9287 Y47.6757
N0410 X52.5362 Y45.6137
N0420 X52.9551 Y44.9758
N0430 X54.5560 Y43.6976
N0440 M05
Amir
**Even a clock that does not work is right twice a day**
« Reply #12 on: June 29, 2010, 03:25:44 AM »
Hi Hood,
I have seen that Option on General config and works only When Loading The program but doesnt apply on RFH. That option is the solution if it Works with RFH. If that option is not ticked on General Config, It will be doing the same thing as RFH when loading Gcode program all the Macro are Triggering. I hope that option will be available as a command. Thanks for your Help
Thanks Again
Renato
« Reply #13 on: June 29, 2010, 03:30:15 AM »
I thought that may be the case.
 Have you tried the Set Next Line rather than RFH?
« Reply #14 on: June 29, 2010, 03:57:44 AM »
Hello  hood,
Thanks for the information, I will try that option tomorrow morning and will let you know.
thanks for the great support
Renato
« Reply #15 on: June 29, 2010, 11:31:21 AM »
Is it true that you said M71 does work when running, but turns on and OFF when RFH ? You have only one M71 call, right? It couldn't be a "race" condition in the execution of M71?
« Reply #16 on: June 29, 2010, 06:07:05 PM »
Hello Peterf
Thanks again for the help. Yes M71 executes properly when called on a GCODE program. But M71 turns on and OFF when RFH. I forgot to mention that M70 turns OFF M71. Its similar if you tick off the option under general config  IGNORE M CALLS WHILE LOADING and you load a GCODE Program. Sorry I did not quite understand what you meant by "RACE".  If there is an OEMButton that will do "Ignore M calls while loading "it will fix the problem....Thanks in Advance
Regards
Renato
« Reply #17 on: June 29, 2010, 06:15:28 PM »
Hello Hood,
I have tried SET NEXT LINE this morning and seems to be working. I will do a bit more testing. Thank you for the Idea. I still have one last question if you could Please give me a starting point on the best way to deal with tool offset.
I have 5 router heads on the Z axis  and individually turn on. Which is the best way to Do individual   OFFSET on  all four Spindle Motor to the first Motor? I know i am asking too much but dont know where to start at this stage.
Thanks again
Renato
« Reply #18 on: June 30, 2010, 12:39:40 AM »
I believe rev4  when its released will have support for multihead spindle offsets but until then you will probably have to use work offsets.
« Reply #19 on: June 30, 2010, 01:20:33 AM »
Do you know when Rev4 is going to be release?
Renato
