Hello Guest it is June 13, 2026, 08:31:54 AM
Author Topic: Move mouse in circles, steppers run great..  (Read 11255 times)
« on: March 19, 2010, 09:02:21 PM »
Running mach 3, windows xp home.. For some reason when i am moving my mouse around without stopping the steppers work perfect.. If i stop moving my mouse the steppers get choppy,  miss steps, turn the opposite way, untill i move my mouse again.. any help would be great..
Re: Move mouse in circles, steppers run great..
« Reply #1 on: March 19, 2010, 10:20:54 PM »
I have also noticed that on the diagnostics screen that my pulse frequency is normally around 5000.. when i move my mouse it climbs to 24059..
« Reply #2 on: March 19, 2010, 10:24:57 PM »
You probably have some software that's interfering with Mach3.
 24,000-25000 is what you should normally see.
« Reply #3 on: March 19, 2010, 10:27:40 PM »
I have changed my freq to 75KHz which kicks it up to 25000 and same issue.. i move my mouse and freq climbs to around 60000 and they run fine...
« Reply #4 on: March 19, 2010, 10:32:01 PM »
Wen you change to 75Khz, you should be seeing 75,000, not 25,000.
Run Drivertest.exe in the Mach3 folder.
« Reply #5 on: March 19, 2010, 10:34:52 PM »
I have run driver test a bunch of times.. looks like the Rocky's... I load special driver runs even worse.. I did a fresh copy of windows to limit any junk that i had and it still shows up..
« Reply #6 on: March 19, 2010, 10:37:16 PM »
What kind of PC?
« Reply #7 on: March 19, 2010, 11:51:55 PM »
Pent 4 2400MHz, 1 gig ram, asus board, nvidia video card..
