Hello Guest it is June 10, 2026, 06:55:22 PM
Author Topic: high speed encoders  (Read 24890 times)
Offline tantan
  •  130 130
high speed encoders
« on: March 06, 2010, 09:34:33 AM »
hi,
i have a pokey with an encoder connected to pin 1 and 2, nothing else is connected to it. if i configure it as a normal encoder every thing works well, but if i enable the high speed encoder option in the pokeys configuration screen the raw encoder values don't increase or decrease while the numbers 1 and 2 in the configuration screen blink while i am turning the encoder. i use the latest pokey software, i upgraded the firmware of the pokey and i use the latest mach version.
hope you help.
tantan
the netherlands
Offline borisz
  •  220 220
    • www.poscope.com
Re: high speed encoders
« Reply #1 on: March 06, 2010, 12:45:49 PM »
Hi!
Do not use fast encoders with Mach plugin yet.
New plugin which will support fast encoders is under work and shoiuld be released soon.
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Offline tantan
  •  130 130
« Reply #2 on: March 07, 2010, 07:09:59 AM »
oke boris thank you for your reply,
i thought that high speed mpg's where working allready, i'll wait for the update.
thanks
tantan
« Reply #3 on: March 07, 2010, 11:56:14 AM »
Fast Encoders IS supported in the latest Mach 3 plugin
I guess Boris and them are doing something in the firmware.
scott
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #4 on: March 07, 2010, 12:01:38 PM »
Will check firmware.
regards
Boris
« Last Edit: March 07, 2010, 12:06:57 PM by borisz »
Offline tantan
  •  130 130
« Reply #5 on: March 07, 2010, 12:18:00 PM »
thanks scott and boris.
if you need more info don't hesitate to ask.
tantan
the netherlands
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #6 on: March 08, 2010, 11:09:39 AM »
Can you please download latest software from www.poscope.com and test it.
regards
Boris
Offline tantan
  •  130 130
« Reply #7 on: March 08, 2010, 12:24:37 PM »
hi boris an scott,
i have tested the new software, pokeys seems to work if i open the raw values window i can see the values changing. if i have mach3 simultaneously started i see the value in mach3 (x-axis dro) changing but not i a right way; it is more or less fluctuating. if i close the raw values window of the pokeys software mach stops changing the values at all. if i open the raw values window in pokeys again the machdro starts to move again. if i check the pokeys screen in mach the mpg value changes between 0 and the value which is presented in the raw values pokeyscreen.
i hope i am clear in my explanation
thanks
tantan
the netherlands
« Reply #8 on: March 09, 2010, 06:39:39 AM »
I have sent Brian the Source code, so he can look it over, to see if I am screwing up the code in the plugin, (always a possibility), but I dont understand why it was working, and now it is not, and I havent changed that code since it was published a while back.
scott
Offline tantan
  •  130 130
« Reply #9 on: March 09, 2010, 01:30:26 PM »
hi boris and scott,
i made a bit of progress. i had windows xp with servicepack 2 installed, i installed sp3. the mpg works now but not smoothly at all. i tried different settings in the calibration window but nothing gave good results.
tantan
