May 25, 2012, 08:02:09 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  PoKeys (Moderator: NeoTO)
| | |-+  Feed & Speed Over Ride
Pages: « 1 2   Go Down
Print
Author Topic: Feed & Speed Over Ride  (Read 1700 times)
M250cnc
Active Member
Offline Offline
View Profile
« Reply #10 on: February 08, 2010, 09:11:05 AM »
Hood, thanks for the heads up, but haven't got round to using it on the lathe yet.
I suppose i could just disable my brain if i wanted to use threading, which i understand is now only version 033 because of some other problem.
Phil
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #11 on: February 08, 2010, 09:21:20 AM »
Phil
Not sure about that, think if threading was working for you before then it should work with any version, the updates in threading were for certain computers. Also it will only affect the PP (not sure if you are?), if you are using the SS then none of the changes in threading will affect it as they were in the driver and the SS doesnt use the driver, only the PP does.
M250cnc
Active Member
Offline Offline
View Profile
« Reply #12 on: February 08, 2010, 10:38:14 AM »
Hood thanks once again, on the lathe i am using the SS so i will leave my brain enabled when i connect the pots. Grin
Phil
Active Member
Offline Offline
View Profile
« Reply #13 on: February 08, 2010, 11:23:45 AM »
Ah no, I thought you were meaning 033 version of Mach and the threading fixes. You will still need to disable the brain or should I say you may need to, only testing will tell you for sure.
Pages: « 1 2   Go Up
Print
Jump to:
