May 25, 2012, 03:33:37 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Mach3 and AhHa break out board
Pages: 1   Go Down
Print
Author Topic: Mach3 and AhHa break out board  (Read 1260 times)
seanfinn
Active Member
Offline Offline
View Profile
« on: January 14, 2010, 03:17:07 PM »
Hello everybody
I want to up grade my Bridgeport Series 1 CNC Mill control software from Machine master using an AhHa design break out board to Mach 3.
Will Mach 3 run using the AhHa break out board? Or do I need a different break out board to interface with the Mach3 software and the bridgeport mill ?
Sean Finn
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: January 14, 2010, 05:14:12 PM »
Dont know anything about AHHA stuff but if they are steppers and the drives accept Step/Dir inputs then likely all that will be needed is a breakout board, you could even connect direct I suppose but personally I prefer breakouts.
BClemens
Active Member
Offline Offline
View Profile
« Reply #2 on: January 14, 2010, 05:55:36 PM »
Hood,
My recollection of AhHa is that you are correct. And as I remember, AhHa OS was written in a version of visual basic and was delivered as serial data. The 15 pin serial port was the only interface with the machine from the operating system and in that light; are the driver boards going to work? A currently available breakout board would bring the system up to the standards of control offered by the Mach OS but the driver system may not be capable....
Active Member
Offline Offline
View Profile
« Reply #3 on: January 14, 2010, 06:30:36 PM »
Never seen one, do recall reading some info about them, whether here or on another forum I dont recall but I know John S has a machine with AHHA so he would know for sure.
bowber
Active Member
Offline Offline
Kirkby Stephen,Cumbria, UK
View Profile
« Reply #4 on: January 15, 2010, 07:07:04 AM »
I sold my Ahha board and fitted new drivers and breakout board as I didn't have info for the current drivers plus they were really old and single step only.
My mill was quite small though so the 10amp drivers only cost around £200 for all three + a simple breakout board.
Mine ran from a dos pc with Ahha artisan and I seem to remember it used a serial cable, I'll have to find the cable and look as it was a few years ago now.
Steve
gaanes
Active Member
Offline Offline
View Profile
« Reply #5 on: September 07, 2010, 01:13:22 PM »
I have the same issue- my cable from the computer is a 37 pin cable. Any info on your conversion yet? Where might I get new drivers to fit the ahha power supply?
arturod
Active Member
Offline Offline
View Profile WWW
« Reply #6 on: September 08, 2010, 09:35:31 AM »
I have never seen the original AHHA breakout board, but I can tell you I have sold lots of boards to users doing the same upgrade.
Take a look at some options: http://www.cnc4pc.com/Store/osc/index.php?cPath=33.
Arturo Duncan
http://cnc4pc.com
Pages: 1   Go Up
Print
Jump to:
