May 25, 2012, 01:40:18 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  PLease Help with code
Pages: 1   Go Down
Print
Author Topic: PLease Help with code  (Read 764 times)
M250cnc
Active Member
Offline Offline
View Profile
« on: December 22, 2009, 09:59:34 AM »
This is the code on a button to zero machine co ordinates
What would be the code to set the dro to another dro
SetMachZero(2)
call SetDRO( 2, 0 )
So that dro 2 is the same as dro 20 as an example
I am sorry but i don't want to learn another app  Grin
melee
Guest
« Reply #1 on: December 22, 2009, 11:32:34 AM »
Hi
You could do it this way
SetOEMDRO( 2, GetOEMDRO(20) )
(NB. SetDRO and GetDRO are deprecated from v2.6*********)
regards
Melee
M250cnc
Active Member
Offline Offline
View Profile
« Reply #2 on: December 23, 2009, 01:03:41 AM »
Melee
Thanks for the reply, unfortunately it did not do what i wanted it too.
Phil
melee
Guest
« Reply #3 on: December 23, 2009, 04:39:12 AM »
Hi
You will need to be specific as to the exact code you used, where you put it and how it is activated.
SetOEMDRO( 800, GetOEMDRO(801) ) for instance, WILL set the X axis main DRO to the contents of the main Y axis DRO.
regards
Melee
M250cnc
Active Member
Offline Offline
View Profile
« Reply #4 on: December 23, 2009, 05:29:08 AM »
Hi & thanks
I want to set X machine Co Ord OEM83 dro to X Ref POs Offset OEM33 Dro
I set it as to the format you said would work but it doesn't.
What i am trying to achieve with the press of a button is to set machine co ordinates (X=83) to that  axis offset dro (X=33)
melee
Guest
« Reply #5 on: December 23, 2009, 09:52:11 AM »
Ahhh I see,
Unfortunately I suspect you will be unable to set the Machine Axis Co-ordinates to anything, except 0 when referencing to Home.
The machine co-ordinates are absolute and physical.
If you could change them to another figure ( even an offset of themselves ), the controller would be unable to tell where the machine axes were and would happily crash at speed through the home positions.
I actually  tried changing the values through MachMad and whilst you can see it change, it is immediately returned to its original value.
regards
Melee
M250cnc
Active Member
Offline Offline
View Profile
« Reply #6 on: December 23, 2009, 11:55:42 PM »
Melee,
Thanks for your help on this, but a bit of a shame really.
Any machine owners who do not use homing switches and hard limits, "and there seem to be lots", makes life is harder.
Phil
Graham Waterworth
Administrator
Offline Offline
West Yorkshire, England
View Profile WWW
« Reply #7 on: December 26, 2009, 06:09:26 AM »
If you look in Config..Homing/Limits you can specify a home offset for each axis there. You can not change it on the fly but if the offset is static it will work, I use it for my tool changer.
Graham
G-Code is on the cutting edge
Autovalues Engineering, CNC machining specialists, Bradford, England
M250cnc
Active Member
Offline Offline
View Profile
« Reply #8 on: January 01, 2010, 07:57:05 AM »
Thanks Graham
Pages: 1   Go Up
Print
Jump to:
