Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 24, 2012, 06:41:28 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Galil
(Moderators:
smurph
kcrouch
Re: Galil controller compatability (what works with the plugin)
Pages:
1
2
Go Down
« previous
next »
Author
Topic: Re: Galil controller compatability (what works with the plugin) (Read 2341 times)
Jeff_Birt
Active Member
Online
on:
April 15, 2009, 06:35:53 PM »
I have not looked at the newest code but it sounds like you guys are doing great things. When I first implemented the extended I/O in the Galil plug-in I used a user program on the econo cards to poll the extended inputs and write them to the unused aux encoder registers. This allowed the extended inputs to be read regularly without the excessive delay of trying to poll them one at a time. Has this been carried throughly? I am getting ready to update my project that uses the Galil in the near future.
Happy machining , Jeff Birt
Check out
www.soigeneris.com
smurph
Active Member
Offline
Reply #1 on:
April 15, 2009, 07:12:20 PM »
Jeff,
Your code is still there and it should still work. I don't have one of those controllers to test it out though. But if it doesn't work, then we'll get it working somehow. When you get ready, we'll get you hooked up on CVS.
Steve
Jeff_Birt
Active Member
Online
Reply #2 on:
April 15, 2009, 07:42:38 PM »
Have you guys considered upgrading to an SVN system? If not I'll install a CVS system on a separate box. I don't want to mix SVN and CVS on my main dev machines.
I'll grab the source in a few days and see how things go on my system. I need to get the Galil user program posted to so others can do a similar thing if needed.
Check out
www.soigeneris.com
kcrouch
Active Member
Offline
In way too deep!!!
Reply #3 on:
April 19, 2009, 09:36:23 AM »
I'm happy to report that the Galil 2040 (USB) is working fine with the new V4.1 or later plugin. I have tested it using both contour mode and LI mode and while both work, I find that the LI mode is smoother.
Kenny
Having way too much fun! Something must surely be wrong.
robertmonroe
Active Member
Offline
Reply #4 on:
June 01, 2009, 11:40:58 PM »
The DMC-18x2 econo controllers not accepting binary is that a problem generating GCode with Mastercam X3 or VCrave Pro 5?
robertmonroe
Active Member
Offline
Reply #5 on:
June 02, 2009, 02:49:59 AM »
When I read the complete specifications for both the DMC-18x2 and DMC-21x3 controllers, I read the follwing:
"Commands are sent in ASCII. A binary communication mode is also
available as a standard feature" infact it says the same for the Accelera boards too.
Why can't the DMC-18x2 be set for binary and avoid the slowness of it?
kcrouch
Active Member
Offline
In way too deep!!!
Reply #6 on:
June 02, 2009, 07:37:08 AM »
Robert,
The latest versions of the plugin will recognize your controller and use the appropriate communication mode. No worries. Just be sure to use the latest firmware for your board and the latest drivers from SmartTerm and you should have no problems wih communication speed. I have both boards here and they work fine with the new plugins.
If Mach is happy with your g-codes, the new plugins will be happy too.
Kenny
robertmonroe
Active Member
Offline
Reply #7 on:
June 02, 2009, 09:46:32 AM »
Great news!
I have a chance to acquire a DMC-20x0 or a DMC-18x2, which would be better?
SmartTerm? Can you share a link for that please?
Robert
kcrouch
Active Member
Offline
In way too deep!!!
Reply #8 on:
June 02, 2009, 10:09:12 AM »
Robert,
Your choice will depend mostly on what tou can locate for an interconnect board. For the 2143 you can use an ICM-20100 which is relatively inexpensive even new. The 1842 will need an ICM-1900 which is pricier new, but probably more easily available used. The 1842 will also have analog inputs, which are nice, but not necessary for most people. My personal choice is the 21x3 series with a RIO connected via Modbus to handle extra I/O both digital and analog.
Kenny
smurph
Active Member
Offline
Reply #9 on:
June 02, 2009, 10:46:19 AM »
I like any of the remote controllers better. Just easier to locate them as the Mach PC doesn't have to be as close to the machine. The 20x0 USB controller works. Kenny tested it. I would get with the 20x0 because it comes standard with extended I/O if you wanted to make use of that. PCI is going the way of ISA and pretty soon, the new motherboards won't even have a regular PCI slot. My latest PC only has one PCI slot. The rest are all PCI express.
But I'm with Kenny on the 21x3 series. It's my favorite as well. It's just a really nice package for doing what we want to do with them.
Steve
Pages:
1
2
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
