Hello
Guest
it is
June 11, 2026, 08:41:32 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Newfangled Solutions Mach3 Wizards
(Moderator:
Ron Ginger
Tool pauses at X axis while cutting circles or threading?
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Tool pauses at X axis while cutting circles or threading? (Read 88657 times)
radioactive
63
on:
May 23, 2009, 10:52:27 AM »
While cutting a circle (0.86" diameter, 1" deep, spiraling downward toolpath) the tool moves along great except it pauses very briefly each time it crosses the X axis. Why does it do this? It does the same thing when I am cutting external threads on the same part.
I'm using the NFS wizards to create the toolpaths (2.83 I think) and version 3.042 of Mach 3.
Chaoticone
5,624
Precision Chaos
Re: Tool pauses at X axis while cutting circles or threading?
Reply #1 on:
May 23, 2009, 11:04:54 AM »
Have you checked your backlash for the X and Y?
If you could see the things I have in my head, you would be laughing too.
radioactive
63
Reply #2 on:
May 23, 2009, 11:25:33 AM »
No, I haven't done that yet. I'll try to get that done this afternoon.
I don't think that is the issue because I seem to recall cutting a different part a few weeks ago where it didn't pause like this.
ger21
6,295
Reply #3 on:
May 23, 2009, 11:33:16 AM »
CV mode?
SteinarN
155
Reply #4 on:
May 23, 2009, 12:19:42 PM »
Quote from: ger21 on May 23, 2009, 11:33:16 AM
CV mode?
Me think also.
MachineMaster
150
Reply #5 on:
May 23, 2009, 02:13:21 PM »
Show your code.
radioactive
63
Reply #6 on:
May 23, 2009, 04:29:33 PM »
It appears as though I have 0.002" of backlash on the Y axis. X and Z were about 0.0004 and 0.0001.
Here's a tidbit from the code for the finish pass of the circle that pauses at the X axis each time.
(***** Circular Groove/Cutout *****)
M6 T3
M03 S4000
M9
G00G43 H3 Z0.1
G00 X0.805 Y0.1875
G41 P0.125
G01 X0.6175 F25
G03 X0.43 Y0 R0.1875
F25
G02 X-0.43 Y0 R0.43 Z-0.025
X0.43 Y0 R0.43 Z-0.05
X-0.43 Y0 R0.43 Z-0.075
X0.43 Y0 R0.43 Z-0.1
X-0.43 Y0 R0.43 Z-0.125
X0.43 Y0 R0.43 Z-0.15
X-0.43 Y0 R0.43 Z-0.175
X0.43 Y0 R0.43 Z-0.2
X-0.43 Y0 R0.43 Z-0.225
X0.43 Y0 R0.43 Z-0.25
X-0.43 Y0 R0.43 Z-0.275
X0.43 Y0 R0.43 Z-0.3
X-0.43 Y0 R0.43 Z-0.325
X0.43 Y0 R0.43 Z-0.35
X-0.43 Y0 R0.43 Z-0.375
X0.43 Y0 R0.43 Z-0.4
X-0.43 Y0 R0.43 Z-0.425
X0.43 Y0 R0.43 Z-0.45
X-0.43 Y0 R0.43 Z-0.475
X0.43 Y0 R0.43 Z-0.5
X-0.43 Y0 R0.43 Z-0.525
X0.43 Y0 R0.43 Z-0.55
X-0.43 Y0 R0.43 Z-0.575
X0.43 Y0 R0.43 Z-0.6
X-0.43 Y0 R0.43 Z-0.625
X0.43 Y0 R0.43 Z-0.65
X-0.43 Y0 R0.43 Z-0.6625
X0.43 Y0 R0.43 Z-0.675
X-0.43 Y0 R0.43
X0.43 Y0 R0.43
G00 Z0.1
G03 X0.6175 Y-0.1875 R0.1875
G40
G00 X0.805 Y-0.1875
MachineMaster
150
Reply #7 on:
May 23, 2009, 08:18:12 PM »
See if some of the settings in this file help.
ger21
6,295
Reply #8 on:
May 24, 2009, 06:28:12 AM »
Do you have backlash compensation turned on?
vmax549
Reply #9 on:
May 24, 2009, 08:43:03 AM »
ALso make sure you are running in CV mode(G64) not exact stop mode(G61). The wizard tends to assume you are in the correct modes(;-)
Just a thought, (;-) TP
Print
Pages:
1
2
3
Go Up
« previous
next »
