Hello Guest it is June 10, 2026, 07:07:48 AM
Author Topic: z axis  (Read 19647 times)
Offline Bill_O
  •  611 611
z axis
« on: May 19, 2009, 09:01:25 AM »
How do I set up PoKeys to use an analog input for the Z axis?
Bill
Offline borisz
  •  220 220
    • www.poscope.com
Re: z axis
« Reply #1 on: May 19, 2009, 09:29:43 AM »
User manual is your friend: http://www.poscope.com/uploads/files/PoKeys55.pdf
Page 7 ;)
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Offline Bill_O
  •  611 611
Re: z axis
« Reply #2 on: May 19, 2009, 09:36:52 AM »
Boris,
Analog input only gives the choices of X, Y , RotX, RotY and Throttle. No Z axis.
Bill
Offline borisz
  •  220 220
    • www.poscope.com
Re: z axis
« Reply #3 on: May 19, 2009, 09:41:22 AM »
Use one of that axis instead of Z.
What aplication needs Z axis on joystick? I did not seen Z axis on jostick.
regards
Boris
Offline Bill_O
  •  611 611
Re: z axis
« Reply #4 on: May 19, 2009, 10:10:00 AM »
Boris,
I am using a joystick for the x and y. I want to use a spring return pot for the z axis.
Bill
Offline borisz
  •  220 220
    • www.poscope.com
Re: z axis
« Reply #5 on: May 19, 2009, 10:24:21 AM »
Can you use one of that axis: RotX, RotY and Throttle
Z Axis is not supported now.
regads
Boris
Offline Bill_O
  •  611 611
Re: z axis
« Reply #6 on: May 20, 2009, 06:49:10 AM »
Boris,
In Mach I have x,y,z,a,b and c axis. Which one is rotx and roty?
Bill
Offline borisz
  •  220 220
    • www.poscope.com
Re: z axis
« Reply #7 on: May 20, 2009, 06:52:37 AM »
Now it is clear. We are talking about apples and peaches :)
PoKeys is joystick emulator and axes on PoKeys are emarked as on Joysticks.
My opinion is that you can assign any joystick axis to any Mach axis.
regards
Boris
