May 24, 2012, 10:22:49 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Screen designer tips and tutorials
| | | |-+  Where is the current screens saved?
Pages: 1   Go Down
Print
Author Topic: Where is the current screens saved?  (Read 1584 times)
SteinarN
Active Member
Offline Offline
View Profile
« on: April 12, 2009, 06:42:16 PM »
I downloaded the Mach3 screen designer. I would like to play with the standard screens, see what I can change. I suppose it is possible to load the standard screens into the screen designer, but I cant find a file for the standard screens. Does such file exists and if so where can I find it?
I have found all the bitmaps for the backgrounds and buttons though.
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: April 12, 2009, 06:50:40 PM »
Its in the C:\Mach3 directory, its called 1024.set
SteinarN
Active Member
Offline Offline
View Profile
« Reply #2 on: April 12, 2009, 06:59:20 PM »
Ahh, thanks Hood!  Smiley
SteinarN
Active Member
Offline Offline
View Profile
« Reply #3 on: April 13, 2009, 01:33:16 AM »
My desktop didn't like that program at all. It opens fine, but when I load the 1024 file it immediately runs into trouble. The PC is running at 100% load for a considerable time, say 10 to 15 sec before anything happens, then all the screens load simultaneously, a terrible mess. If I hit escape then only one screen is visible, but it is still very unstable, doesn't look like the program read the file completely correct and it crashed two times in 20 min of trying to get it to work. I have an old xp version.
Is it something with my PC? Should it work on any PC?. I tried to run it in compatibility modes for windows 2000. It didn't help.
« Last Edit: April 13, 2009, 01:36:31 AM by SteinarN » Logged
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #4 on: April 13, 2009, 05:02:47 AM »
Screen 4 doesn't work in Vista.
Try this one.
http://www.machsupport.com/forum/index.php/topic,11122.0.html
SteinarN
Active Member
Offline Offline
View Profile
« Reply #5 on: April 13, 2009, 06:12:29 AM »
Try this one.
I run xp.
SteinarN
Active Member
Offline Offline
View Profile
« Reply #6 on: April 13, 2009, 07:17:06 AM »
I had originaly downloaded the Mach3 screen designer. That didn't work. I downloaded the Screen4. Works like a dream under xp  Smiley
Pages: 1   Go Up
Print
Jump to:
