Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 23, 2012, 10:08:32 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
Mach SDK plugin questions and answers.
Finished Plugins for Download
Map ALL standard Input and Outputs to a New Diagnostic screen!!
Pages:
1
Go Down
« previous
next »
Author
Topic: Map ALL standard Input and Outputs to a New Diagnostic screen!! (Read 2585 times)
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
on:
March 14, 2009, 05:49:09 PM »
What the plug in does is watch directly the Signals Of
ALL
the "Ports and Pins"
Input Signals
and
Output Signals
so you dont have to use a: "Brain", or "Macropump" or other VB device to map these signals to a Screen LED
that represents that Signal.
The Screenset called:
"1024 TestIO.set" is the standard OEM Mach Mill Screen
with
ALL
the
standard Input/Output signals
on the
redone
Diagnostics page
Below is a list of the User LEDs that the Plug in uses
If you want to use this plug in and screen set
then you will need to check to make sure that your Wizards,
screens, or other items are not ALSO using these.
The Plug in will "tie in" LEDs for the Standard
Input and Output Signals under Ports and pins for:
Inputs:
1). OEMTrigger's 1-15
Outputs:
1). OUTPUT's 7-20
2). Charge Pump, Charge Pump2, and Current Hi/Low
ULED's Used for Input Signals are:
1). 1301-15 is used for OEM trigs 1-15
ULED's Used for Output Signals are:
1). 1316-32 is used for Outputs 7-15,Charge Pump,
Charge Pump2 and Current Hi/Low
Screen shot of NEW (redone), Mach3 OEM screen for Mill with the Modified Diagnostic screen with ALL the Signals mapped to the LEDs on that screen set.
Screen shot below.
Plugin installer attached.
the installer will Install the Screen set to the standard directory you will need to do a View->Load Screens and pick: "1024TestIO.set"
Also enable the Plug in called: "TestIO.dll" the close and reopen mach, your ready to go at that point.
NOTE: Only Input Signals, and Output Signals that you have Enabled in Port and Pins will activate.
Scott
*********** EDIT 3/19/09 I added the Fixed Screen Set that Greg fixed and did below to this installer, so if you have the old one, uninstall it though "add/remove" programs then install this one.*********
TestIOv1-1.zip
(252.34 KB - downloaded 217 times.)
Last Edit: March 19, 2009, 08:18:21 AM by poppabear
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
RJ Hohman
Active Member
Offline
Re: Map ALL standard Input and Outputs to a New Diagnostic screen!!
Reply #1 on:
March 16, 2009, 12:56:11 AM »
Hi Scott,
I tried the screen set. It loaded fine except that all screens were about 1/4 of my normal screen size. My screen size is 1078 x 768. There was also some text that was
down and left of the lower left corner of the screen. As best as I can make out it says overir.... . I like the diagnostic screen. Is this a free plugin?
regards,
RJ
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
Reply #2 on:
March 16, 2009, 09:52:52 PM »
RJ the plug in is Free
*********EDIT 19mar09, yea the plug in is free for any and all, no point in charging for this one ************
enjoy,
scott
Last Edit: March 19, 2009, 08:29:10 AM by poppabear
RJ Hohman
Active Member
Offline
Reply #3 on:
March 18, 2009, 10:59:25 PM »
Scott,
I looked and the Auto Screen enlarge was checked. I made a screen capture of my laptop to show you. Only the Main screen has it visible.
Maybe that is what is causing the small screen size?
regards,
RJ
Greolt
Global Moderator
Offline
Reply #4 on:
March 19, 2009, 12:21:14 AM »
Aha that's the our much loved screen editing program playing funny b%#ggers. They don't call it Scream4 for nothing.
Fancy our Mach guru getting caught with that old chestnut.
I have taken the liberty of repairing the errant objects and posted the set file. Scott is probably tucked up in bed.
Greg
1024TestIO.set
(97.73 KB - downloaded 142 times.)
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
Reply #5 on:
March 19, 2009, 07:01:33 AM »
"Mach Guru"........ hehehe funny.......... not this dog, just fiddled with it alot.
Please, by all means tell me what the "bug" was?? I built the screen in Screen3, not 4.
I dont use Screen4 anymore (since I *Heavy Sarcazm here* Upgraded to Vista), since it is a PIA to use with Vista.
Strangley screen3 works GREAT with Vista.......... go Figure.
but, please tell me and all of us what the Bug in the screen is/was, I will make sure to check my furture screens prior to sending
them out to make sure it is not there.
scott
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
Reply #6 on:
March 19, 2009, 08:21:02 AM »
Greg (and others),
I added the "Fixed" screen set that Greg so graciously fixed for my sorry butt. It is added to the Installer in the first post at the top.
It is version 1.1. You will need to uninstall the old one under add/remove programs, OR, you can just drop Gregs fixed screen into the Mach3
main directory.
Thanks Greg for keeping me honest,
scott
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
Reply #7 on:
March 19, 2009, 08:30:54 AM »
BTW: The plug in for TestIO is free to one and all, no point in charging for it, it was not that complex.
scott
Greolt
Global Moderator
Offline
Reply #8 on:
March 19, 2009, 04:05:06 PM »
Scott
A couple of items on the front page (a DRO and a label) had done what is a common trick in Scream4 and jumped position of their own free will.
They happened to jump so far that you would not see them when editing. They were only small items so you would not notice they had gone missing.
When "auto screen enlarge" is active, it sees these errant items as legitimate part of the screen, and sizes things so that they can be seen.
Hence the picture that RJ posted. Look bottom right hand corner for spindle rpm DRO.
I just put them back in their place and saved the changes.
Scream4 is not so bad. Used with a large monitor most of the quirks disappear. I have little experience with Screen3 and use XP.
Greg
Last Edit: March 19, 2009, 04:14:19 PM by Greolt
RJ Hohman
Active Member
Offline
Reply #9 on:
March 19, 2009, 11:29:51 PM »
Hi All,
Works fine now. Great addition. The only problem now is more things to paly with....just need more time to play!
RJ
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
