Hello Guest it is June 12, 2026, 03:28:56 AM
Author Topic: Rectangle do a oval?  (Read 33260 times)
Offline TDAY
  •  165 165
    • Home CNC Stuff
« on: December 31, 2008, 11:01:23 AM »
Can Rectangle Wizard be made to do a outside Oval shape?Like the pic.
I tried and got a very odd round shape.
Troy
« Last Edit: December 31, 2008, 11:41:36 AM by TDAY »
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Re: Rectangle do a oval?
« Reply #1 on: December 31, 2008, 09:12:20 PM »
I dont think it works very well. I just tried a few examples and when the corner radius gets to big to fit within the rectangle strange things happen. Im not sure if this is a feature of the new cutter comp or it always worked like this. Im testing more now.
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #2 on: January 01, 2009, 06:02:03 AM »
I think its always done this,as iam using Mach R3.038,and have tried this before.
Troy
« Reply #3 on: January 06, 2009, 01:25:38 PM »
actually if you check out the electrical wizard the duplex outlet cover hole is exactly that shape.
chuck
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #4 on: January 06, 2009, 01:44:21 PM »
Ya,but i was doing a outside shape.And i need to be able to change the size of the oval.
Troy
« Reply #5 on: January 06, 2009, 01:50:41 PM »
Troy,
would it be practical to do a rectangle than a circle over it? or a circle than a rectangle to square the sides?
Chuck
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #6 on: January 06, 2009, 03:07:14 PM »
Nice idea,but would be time consuming to run part.I would rather do the Gcoding with Cutter Comp.
I thought the Rectangle wizard could do it,as i have ran other CNCs that had a similar "wizard" that would do oval shapes also.
Troy
