Hello
Guest
it is
June 12, 2026, 03:29:20 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Newfangled Solutions Mach3 Wizards
(Moderator:
Ron Ginger
Rectangle do a oval?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Rectangle do a oval? (Read 33263 times)
TDAY
165
on:
December 31, 2008, 11:01:23 AM »
Can Rectangle Wizard be made to do a outside Oval shape?Like the pic.
I tried and got a very odd round shape.
Troy
Last Edit: December 31, 2008, 11:41:36 AM by TDAY
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Ron Ginger
925
Re: Rectangle do a oval?
Reply #1 on:
December 31, 2008, 09:12:20 PM »
I dont think it works very well. I just tried a few examples and when the corner radius gets to big to fit within the rectangle strange things happen. Im not sure if this is a feature of the new cutter comp or it always worked like this. Im testing more now.
TDAY
165
Reply #2 on:
January 01, 2009, 06:02:03 AM »
I think its always done this,as iam using Mach R3.038,and have tried this before.
Troy
chuckels
57
Reply #3 on:
January 06, 2009, 01:25:38 PM »
actually if you check out the electrical wizard the duplex outlet cover hole is exactly that shape.
chuck
TDAY
165
Reply #4 on:
January 06, 2009, 01:44:21 PM »
Ya,but i was doing a outside shape.And i need to be able to change the size of the oval.
Troy
chuckels
57
Reply #5 on:
January 06, 2009, 01:50:41 PM »
Troy,
would it be practical to do a rectangle than a circle over it? or a circle than a rectangle to square the sides?
Chuck
TDAY
165
Reply #6 on:
January 06, 2009, 03:07:14 PM »
Nice idea,but would be time consuming to run part.I would rather do the Gcoding with Cutter Comp.
I thought the Rectangle wizard could do it,as i have ran other CNCs that had a similar "wizard" that would do oval shapes also.
Troy
Print
Pages:
1
Go Up
« previous
next »
