Hello Guest it is October 22, 2026, 10:47:08 AM
Author Topic: Trouble With Arcs  (Read 16346 times)
Offline atanq
  •  19 19
Trouble With Arcs
« on: December 29, 2008, 12:09:54 PM »
Hello,
I have the following .Lcam file, which is a guitar scratch plate.  However, when I try to lazy cam it, I get multiple chains for the main outline.  I would like it to cut in one continuous motion.  Anybody got any ideas?
I'm using LCam Version 3.00.
Thanks in advance, Guys
Offline docltf
  •  354 354
Re: Trouble With Arcs
« Reply #1 on: December 29, 2008, 02:17:47 PM »
here is a cleaned up lcam for you. lcam is a beta with many bugs. it can't handle that much confusion.
Offline atanq
  •  19 19
« Reply #2 on: December 29, 2008, 02:29:13 PM »
That's amazing!!!
Please tell me how you did that, friend.
Aaron.
Offline docltf
  •  354 354
« Reply #3 on: January 01, 2009, 02:53:37 AM »
Hi,Aaron
that is a lot of explaining.if you look at the lcam you posted,at the chain and layer menu on the left you will see a pretty good list of stuff.then look at the menu of the lcam i sent you.that shows how much stuff had to be deleted.then i had to
connect all of the broken chains that i could.the chains that would not connect had to be repaired .the repairing process went like this.i took what was cleaned up and made a g-code and loaded mach.then i used the text editor to remove rapid moves
and connect the broken chains.imported the g-code back into lcam and generated you a lcam file.your dxf was a sad one.lcam has a lot of power,but is very sensative to bad drawings.the more you play with it the better it gets. lcam cannot
repair a bad drawing and it can have trouble with a good one.when you get you drawings down to where their are pretty good lcam can write a ton of code for you.i got lcam jerked around to do 4th axis stuff to.good luck to you!
bill
Offline atanq
  •  19 19
« Reply #4 on: January 01, 2009, 05:46:35 AM »
Hi Bill,
Thanks for that, I guess the way forward is to ensure a proper .dxf in the first place.  I looked at my original .dxf and found that there were quite a few breaks in the lines when zoomed in close-up.  Now, I can go straight from my .dxf into lazy cam!
Thanks for all the help, Bill.
« Reply #5 on: January 01, 2009, 08:19:29 AM »
Bill's the man, for sure....    8)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #6 on: January 01, 2009, 11:57:29 AM »
Hi, Aaron
Posting your .dxf file also help's us help you better as the issues most often start there.
Thanks, Chip
Offline atanq
  •  19 19
« Reply #7 on: January 02, 2009, 12:42:51 PM »
Splendid help, everyone.
Is there a way to mark this topic as closed?
