Hello Guest it is November 13, 2026, 10:45:16 AM
Author Topic: Mach upgrade  (Read 38197 times)
Re: Mach upgrade
« Reply #10 on: December 27, 2008, 06:47:41 PM »
ok, did you copy the xml before the upgrade? If so copy and paste it back into the Mach 3 folder.
Re: Mach upgrade
« Reply #11 on: December 27, 2008, 06:57:33 PM »
Copy and pasted still no response from the router........ Also on the start up screen when I click on tribal router it still pops up a pic that says version2.0 before the control screen appears???
Re: Mach upgrade
« Reply #12 on: December 27, 2008, 06:59:31 PM »
If you go to the Help menu in Mach and then About it will show the version you have.
Ok, if you can attach the xml I will have a look at it and see if there is anything wrong in it.
Re: Mach upgrade
« Reply #13 on: December 27, 2008, 07:15:17 PM »
Says ver 3.04. I can't get the xml to attach. It says there is a file like that already posted. I think I tried to send the xml to you or Chaotic in Oct.
Re: Mach upgrade
« Reply #14 on: December 27, 2008, 07:17:27 PM »
ok, just copy the xml to your desktop and rename it to moto.xml and it should attach.
In the mean time try reinstalling Mach again.
Re: Mach upgrade
« Reply #15 on: December 27, 2008, 07:24:54 PM »
Well your helping me learn how to use my computer better whether you wanted to or not. I thank you for your patience and help. Lets see if this will work.
Re: Mach upgrade
« Reply #16 on: December 27, 2008, 07:32:28 PM »
Just looked at the xml and it looks fine and actually have your old one as well and its identical as far as pin setups etc .
Try the reinstall and make sure you dont  uncheck the parallel port driver option.
If that fails run the drivertest and see if its ok, its in the Mach3 folder, just double click it.
Wont be around much longer as its 1:30am but I am sure someone else will help you out if these things dont work.
Re: Mach upgrade
« Reply #17 on: December 27, 2008, 07:35:56 PM »
Thanks Hood, Just reinstalled and got it moving looks like I'm going to have to go back through and readjust all my settings.
What improvments will this do for me???
Thank you very much for all your help.
Nick
Re: Mach upgrade
« Reply #18 on: December 27, 2008, 07:39:45 PM »
Not sure what you mean by "What improvments will this do for me???"
If you are meaning what is better about the later version it depends what you were previously running, there have been huge improvements to lots of things and the latest one has been cutter comp so if you use that it should be good for you.
Re: Mach upgrade
« Reply #19 on: December 27, 2008, 07:45:16 PM »
Didn't mean it as an insult. I had ver 2.0  and I don't keep up on this forum as much as I should. I cut cabinet parts, signs and a little 3d stuff with my router and am still learning more every day!! I heard that this ver might help with the 3d cuts.
I can't thank you enough for your help!!! Hope you have a great new year!
Nick
