Hello Guest it is October 25, 2026, 11:02:09 AM
Author Topic: driver test  (Read 11751 times)
driver test
« on: December 20, 2008, 10:12:49 AM »
It is clear that I know just enough to be very dangerous.  >:D
I was hoping someone can offer some guidance on two questions I have after running the driver test.
1) When I searched around prior to posting it looks like I have an older test from the screen shots I have seen.  I used the file in the Mach3 folder.  Not sure if there is some type of upgrade or different file I should use?  I have version 2.63.
2) From this image I see a very flat line which I believe is good.   But I am wondering if the longest and shortest times are appropriate?
As always thanks for any help.
Re: driver test
« Reply #1 on: December 20, 2008, 01:00:27 PM »
You will need the latest lockdown of Mach to get the new driver test.
Your driver test looks fairly good :)
