Hello Guest it is November 24, 2026, 09:07:08 AM
Author Topic: Converting a DSP Controller system to Mach 3  (Read 81050 times)
« on: December 19, 2008, 06:19:52 PM »
Howdy all,
I recently purchased a used CNC Router with a DSP Controller system. I can't say that I like the DSP at all. Not enough feedback for me. How easy would it be to change the DSP controller to a computer hookup that I could run with Mach 3?
Keeping in mind that I am pretty much electronically illiterate I need to find a system that would be fairly easy to install.
The CNC is a Chinese unit that runs with 3 steppers and is 110 volts but 3 phase.
Martyn.
Re: Converting a DSP Controller system to Mach 3
« Reply #1 on: December 19, 2008, 07:07:24 PM »
Do you have links to any doccumentation? As it is a stepper system then it will more than likely take Step/Dir inputs so should be possible to convert to Mach without much trouble but without knowing the system its impossible to say how hard it will be.
« Reply #2 on: December 19, 2008, 07:15:14 PM »
Hi Hood,
           Sorry the documentation I have is very poor and the translations are not very good.
I can hook the DSP unit into my computer with a PCI SCSI card. I am going to check tomorrow with my local computer geek  store and find out if I can get a cable with two male ends. Maybe I can hook one to my computer and the other to the input on the CNC machine. I do not know if that would allow me to command the machine or not.
Martyn.
« Reply #3 on: December 19, 2008, 07:17:53 PM »
SCSI will not work from Mach, you will need either parallel port or one of the external devices such as the SmoothStepper.
« Reply #4 on: December 19, 2008, 07:21:11 PM »
Well there goes that idea then, and it was such a nice one too. Can I get a parallel to SCSI cable? Would that work?
« Reply #5 on: December 19, 2008, 07:23:42 PM »
Dont think so :(
If you can scan the schematics you have maybe we can figure it out, some of us speak fluent Chinglish :D
« Reply #6 on: December 19, 2008, 07:31:33 PM »
Hood,
       just took another look at what I have. I have an Adobe PDF file that may, I say again, may be the schematic for the board. Let me know what you think.
Martyn.
« Reply #7 on: December 19, 2008, 07:42:42 PM »
That looks as if it would be fairly easy to convert over,its late here (1:45am) so I will have a better look tomorrow. If I dont post please shout as I have a bad memory :D
« Reply #8 on: December 19, 2008, 07:44:33 PM »
Thank you kind sir, you are a gentleman and a scholar, and there aren't many of us left.
Talk to you tomorrow.
Martyn.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #9 on: December 19, 2008, 09:36:45 PM »
Hi, Martyn
With the PDF file in hand you have most all the info you need to start planning this conversion.
It's a matter of removing the 50 pin interface board and installing a breakout board (BOB) w\Spindle control options.
Tracing the existing Interface boards 50 pin connector and making a 50 pin to 25 pin adapter cable mite also be a way to go.
At least your looking at stepper controls that are step & direction and sensors that are adaptable hear.
Chip
