Hello Guest it is November 23, 2026, 05:10:50 PM
Author Topic: Mach3 Error codes  (Read 28471 times)
Offline Keith
  •  187 187
Mach3 Error codes
« on: July 12, 2006, 12:30:34 PM »
I just installed the latest version of Mach3 over my existing older version of 3 so I could get at Lcam through Mach. Each time I call the program up,I get an error code(first time it was artcode:9991 and second time was 904,I believe).Then I'm prompted for recovery.If I click 'Yes' it doesn't do anything but blink that warning,if I click 'No' ,it closes Mach3 and then when I retry opening mach3(mill this is) it opens and functions. Whatdaya think?-Keith
Re: Mach3 Error codes
« Reply #1 on: July 12, 2006, 06:32:53 PM »
Will it open if you click on the EXE in the Mach3 directory
www.newfangledsolutions.com
www.machsupport.com
Offline Keith
  •  187 187
« Reply #2 on: July 12, 2006, 06:51:48 PM »
Hrrmmm.....it's opens without error that way.  ? A small,'hidden script' window also shows but no error message. What's that about?-Keith
