Hello Guest it is November 13, 2026, 10:36:40 AM
Author Topic: Hot Key F10  (Read 14141 times)
Hot Key F10
« on: December 13, 2008, 10:11:16 AM »
I'm trying to use F10 (function key 10) as a hot key.
I can use all of the other Fkeys.
I am using the 6 Axis screen set.
I noticed that the Feed Rate was using F10, so I used Screen Designer to clear it from those buttons.
But F10 still will not be accepted in the system hot key window. I even tried to paste it in the pop-up window that say "press any key".
I can past other numbers in there but not 121.
Any ideas?
Re: Hot Key F10
« Reply #1 on: December 13, 2008, 10:53:00 AM »
What are you wanting to use the F10 key for?
Re: Hot Key F10
« Reply #2 on: December 13, 2008, 12:17:10 PM »
Jog B axis. It is System Hotkey B/V -- .
Re: Hot Key F10
« Reply #3 on: December 13, 2008, 04:42:42 PM »
Looks like F10 must be reserved in some way :(
Re: Hot Key F10
« Reply #4 on: December 13, 2008, 05:55:33 PM »
Hood, thanks for checking.
The strange thing is that with the 6 axis screen set, the F10 adjusted the feed rate (may be the same in other screens, I did not check).
Which gives me an idea. F10 can be assigned in Screen Designer. So maybe I'll make a phantom B axis jog button and assign it F10.
Thanks again Hood.
Scrappy
