Hello Guest it is October 21, 2026, 08:03:51 AM
Author Topic: V2.81  (Read 65795 times)
Offline TDAY
  •  165 165
    • Home CNC Stuff
Re: V2.81
« Reply #10 on: December 08, 2008, 09:53:41 AM »
Found out why CW and CCW is backwards  :-[ :) I was reading description beside the CW & CCW,that is what is backwards, but when selectting CW or CCW and not going by description,program is right. :)
Sorry for not paying attention.
Troy
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Offline Sage
  •  370 370
Re: V2.81
« Reply #11 on: December 08, 2008, 06:39:07 PM »
Yes. I pointed that out as well.
And I'll repeat it here because your description is still confusing  (to me)
On the pocket data entry screen CW is listed as "climb milling". It is actually conventional milling.
(If you pick clockwise it does generate a clockwise movement - it didn't use to that's waht was fixed in 2.81)
Sage
« Last Edit: December 08, 2008, 06:42:43 PM by Sage »
Offline Sage
  •  370 370
Re: V2.81
« Reply #12 on: December 27, 2010, 04:24:04 PM »
Hi Ron:
Seems this has gone un-corrected.
In the interest of making everything correct could you change the descriptions of CCW and CW in the circular pocket wizard. A CCW path is climb milling and CW is conventional milling while inside a pocket.
 The code does go CW when you select it. It's just the descriptions that need to be corrected.
(or maybe I got confused)
Sage
