Hello Guest it is October 21, 2026, 05:24:45 AM
Author Topic: new computer install question  (Read 14131 times)
« on: November 28, 2008, 05:02:48 PM »
I am going to be using a new computer in my shop, so I need to install Mach 3 onto it. Can I use my same licensee key for the new computer, if so how do I install, I can't remember how I installed on my old one. My license is only two months old. Thanks, Mailman
Re: new computer install question
« Reply #1 on: November 28, 2008, 05:08:35 PM »
Yes you can, just look in your Mach3 folder and you should see a file called Mach1Lic.dat  copy that into your new computers Mach3 folder and next time you start Mach it should be registered.
 If  you already have a machine running on your old computer you can copy the xml into the new one and all of your settings will be transfereed.
« Reply #2 on: November 28, 2008, 05:39:57 PM »
Thanks ,I will give it a shot. Mailman
« Reply #3 on: November 28, 2008, 06:31:42 PM »
also check a file mach3mill.xlm has your settings transfer that over too
« Reply #4 on: November 28, 2008, 07:27:24 PM »
Thanks again, Mailman
