Hello Guest it is October 14, 2026, 09:47:28 AM
Author Topic: Lockdown Ver 3.042.018  (Read 29150 times)
Re: Lockdown Ver 3.042.018
« Reply #10 on: November 17, 2008, 10:04:31 PM »
After a lot of time wasted/spent, have managed to update the video driver.
The RH border issue is still there - has nothing to do with the machine, windows, or the screenset but with the outer frame of the MACH3 window.
The screen is running at 1024x768 on a 17" LCD monitor
The situation has changed slightly with the driver update;
MachBlue now behaves pretty much as would be expected - resizing and filling the window maximised or not (with the exception of the RH border issue).
The base 1024 screenset still behaves as shown in the screenshots above. The Autoenlarge setting has no effect on this.
Maybe the 1024 screen is corrupted? Is there a simple way to extract the 1024 screen set form the install download or perhaps I could just save off the custom setup and re-install (again).
« Last Edit: November 17, 2008, 10:06:34 PM by tech.tron »
« Reply #11 on: November 18, 2008, 01:30:49 AM »
AS I am a new member at this time, was wondering if you figured the problem out yet or not.
I myself have tried running Mach2&3 (trials for now), and have encountered the very similar circumstances while using multiple displays, but not a single display.
Still, wondering if this particular problems been figured out/fixed/whatnot is all.
« Reply #12 on: November 18, 2008, 04:31:23 AM »
Well it's 'fixed' with an updated driver and the MachBlue screenset.
Only upgraded from 2.63 to 3.042.018 as it had become 'lockdown'
Now find there have been two more updates (019 and now 020) in a few days. The change log shows no reference to this issue.
Anyhow, will wait now until the versions stop changing quite so rapidly then try the version available at that time.
Offline Glenn
  •  129 129
« Reply #13 on: November 20, 2008, 03:26:37 PM »
Hey Guys,
    Sorry to jump in here, but GaryB.  you taught me something I've
wondered about for a long time! Thanks very  much!
   This forum is great.  :D
        Glenn
Don't assume anything.....it'll make a Manager out of U and Me!
« Reply #14 on: November 20, 2008, 10:04:44 PM »
Installed 3.042.020 today.
1024 screen is resizing the same as MachBlue now - still no change to RH border strangeness.
