Hello Guest it is November 13, 2026, 09:43:03 AM
Author Topic: Connecting spindle to breakout board  (Read 40667 times)
Re: Connecting spindle to breakout board
« Reply #10 on: June 04, 2013, 06:06:30 PM »
Hi Roy, do you have the pnc3 version of the triac? have you still got your machine? I see your post was quite sometime ago. The initial wiring layout you gave is the same as mine, as well as the brown and prestel controller from the denford triac gsm manual, and I have been scratching my head over this spindle setup for a while now, now I have confidently connected the spindle up correctly. Did however get your machine running correctly as I am still a little confused with regard to the motor tuning setup, steps pe, vel, acc etc on the axis and spindle.
