Hello Guest it is November 17, 2026, 03:06:05 AM
Author Topic: Optional stop in screen  (Read 13620 times)
« on: October 15, 2008, 12:56:54 PM »
Gentlemen,
It is possible to have an optional stop on/off on the screen, instead of going to general config ?
Sometimes I need to stop the gcode file, others don't - for the same code (depends of the number of chips). In this way, the user can switch on/off during a program execution. Feedhold is a little bit scarry, and I had before ruined parts because of feedhold.
(Or can this be done in a different way ?)
Thank you
Re: Optional stop in screen
« Reply #1 on: October 15, 2008, 04:19:30 PM »
The main mach screen, tha one that comes with the program instalation has a button for turnin on and off the optional stop M1,
You can use that one, or if you are using a custom screen you can use the OEM button code is 177
hope that helps
Regards
Fernando
« Reply #2 on: October 16, 2008, 02:14:43 AM »
I do not know how could I missed that one.
Thank you !
« Reply #3 on: October 16, 2008, 07:31:28 AM »
It happens!
Glad i could help
Fernando
