Hello Guest it is October 04, 2026, 08:53:21 AM
Author Topic: Help Using Mach 3...  (Read 45513 times)
Re: Help Using Mach 3...
« Reply #20 on: February 27, 2007, 02:50:22 PM »
LOL!! Thanks for the help man you have no idea how you saved my life here! Thanks Brett and all of you guys!
Roberto
« Reply #21 on: February 27, 2007, 03:03:03 PM »
Ok Brett,
One more thing in MACH2 I changed the feedrate so they will move slower for example in Jog mode so that I could fine tune a depth or move the 0 on the X-AXIS for example... Now If I change the Feedrate they still move at the same speed when I change Velocity of the motors in the motor tuning it does change the velocity but cannot be able to change the feedrate any ideas why??
« Reply #22 on: February 27, 2007, 03:11:03 PM »
Roberto,
    You want to set your accel and vel. as high as possible in motor tuning. To slow down your jog speed, hit the tab key and change the value where the cursor is at in this screen shot. To rapid jog, hold down the shift key while you jog.
« Reply #23 on: February 27, 2007, 03:19:28 PM »
OHHH LOL!! Thanks man!!
Roberto
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #24 on: February 27, 2007, 08:35:45 PM »
Hi, Roberto
Glad to hear it worked out good.
Adjust your velocity "Max speed no lost ssteps" , Accleration "Speed that you don't lose steps from a dead
stop to Max speed".
Set it To what ever your comfortable with, Some of the speeds these machine's can go Wooo To Fast.
Brett taker to Warp-Speed, Chip
« Reply #25 on: February 27, 2007, 08:42:15 PM »
Thanks buddy for the help! Have to read that MACH 3 manual does the Offset feature let`s you enter the offset of the tools so I don`t have to modify my file??
Thanks for the help.
Roberto
Offline Chip
  •  2,055 2,055
« Reply #26 on: February 27, 2007, 10:33:13 PM »
Hi, Roberto
If your using LazyCam you need to select Leadens in the Post G-code window and turn on leadens on in the screen Watch the Video's on LazyCam.
Also set the tool # & info in Mach, and LazyCam enter the Tool #.
Check the Video's Out, Chip
