Hello
Guest
it is
October 10, 2026, 06:14:25 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
motor direction
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: motor direction (Read 16481 times)
ketil1
motor direction
on:
June 22, 2006, 11:04:50 AM »
my x axis is moving in the wrong direction.
The controller must be wired wrong.
Using mach3
any advise or info on how to fix myself.
thanks
Logged
ketil1
Re: motor direction
Reply #1 on:
June 22, 2006, 11:30:32 AM »
Config/Homing & Limits/ REV column. Check or uncheck the box
Logged
method13
71
Re: motor direction
Reply #2 on:
June 22, 2006, 11:37:08 AM »
Using Mach2....
You can reverse the motors under Config. then Motor reversals switch the one you need. Also under config. you can go to homing and switch the direction that you home the machine in if you need to.
Greg
Logged
"Ideas have consequence" Ravi Zaccharias
Print
Pages:
1
Go Up
« previous
next »
