Hello Guest it is November 23, 2026, 02:04:11 PM
Author Topic: 50 in/min but no faster  (Read 35451 times)
Re: 50 in/min but no faster
« Reply #10 on: June 22, 2006, 10:14:10 PM »
You can threadmill any thread you like :)
Did you lower the accel and see what the effect is?
www.newfangledsolutions.com
www.machsupport.com
« Reply #11 on: June 22, 2006, 11:32:44 PM »
I'll give it a try tomorrow but I'll run a program in the air just in case. How much should I drop it by?
Here is a pic of my machine I am roughing a pocket it aluminum, using a 1/2 carbide endmill.
thanks,
Greg
"Ideas have consequence" Ravi Zaccharias
« Reply #12 on: June 23, 2006, 07:59:48 AM »
half the accel as a test..
www.machsupport.com
« Reply #13 on: June 26, 2006, 01:12:26 PM »
So far so good I am cutting aluminum and  am running my feeds slower because lack of rigidity, but it is switching back and forth from G0 to G1 with out any problems. I set the acceleration to just over half of what it was, what should I do now? Keep running test programs gradually moving up the acceleration till it makes a mistake and then back it off a bit?
Greg
« Reply #14 on: June 26, 2006, 04:46:04 PM »
That's generally how it's done. Gradually increase it until it misses steps, than back off 15-20% for a safety margin.
« Reply #15 on: June 26, 2006, 09:19:23 PM »
What about the velocity? Can that be increased? Or just try to find a good balance?
Greg
« Reply #16 on: June 26, 2006, 10:45:16 PM »
You should be able to take up the velocity with the Accel down...
Hope that helps
Brian
www.machsupport.com
