Hello Guest it is November 16, 2026, 08:53:52 AM
Author Topic: Too fast for pully????  (Read 26697 times)
Re: Too fast for pully????
« Reply #10 on: October 09, 2008, 03:44:33 PM »
This is above my knoledge of things.... This sis the file the coumpany I got my router from sent me to run it. What would need to be changed to adjust the spindle speed from the mach screen? Is it a setting I could change in the xml or am I thinking wrong?
Nick
« Reply #11 on: October 09, 2008, 03:55:41 PM »
To adjust the spindle speed from Mach would depend on how your motor is controlled. I am presuming you have a VFD on your motor, this will probably be capable of accepting a 0-10v signal to vary the speed. However to get that signal from the PC you would need to use a board similar to the DigiSpeed from www.homanndesigns.com There are others that make similar products.
« Reply #12 on: October 09, 2008, 08:46:09 PM »
Nick, I have sent you a personal message.
