Hello Guest it is October 22, 2026, 12:22:00 PM
Author Topic: Installation fails during install of 3.041  (Read 53699 times)
« on: October 07, 2008, 08:40:11 PM »
I have an SS board and I was using 2.63 but per the www.warp9td.com I need to use 3.041. I uninstalled 2.63 then tried to install 3.041 and I get an error message that says installation failed. I tried several more times with the same result. Any troubleshooting ideas? Thanks.
Re: Installation fails during install of 3.041
« Reply #1 on: October 07, 2008, 08:43:38 PM »
Sounds like you may not have gotten a complete download. I'd try to download again and then try to install.
« Reply #2 on: October 09, 2008, 10:11:38 PM »
I downloaded 3.042 and it fails to install also. It hangs and when I check the application event log it says it failed in irsetup.exe. This is running on a Dell Inspiron 1525 with 2 GB of memory and Vista Home Premium. I had no problems with 2.63. Anyone have any suggestions?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #3 on: October 10, 2008, 08:44:33 AM »
Make sure that you uninstall the previous version and the driver. There is a newer installer in the new version so it's best to start with a completely clean install.
Happy machining , Jeff Birt
« Reply #4 on: October 11, 2008, 11:01:11 AM »
I did an uninstall and even removed my virus protection in case it was getting in the way. Still no luck. I start installation and nothing happens for quite a while but then eventually a window pops up and says installation has stopped due to an unknown problem. I am still stuck :-(
« Reply #5 on: October 11, 2008, 10:52:36 PM »
Hello,
I would try the newest version of Mach3 (3.042.0xx) and this may fix your trouble. This version has an all new installer, I had seen this problem 5-6 times and knew I needed to do something :) . So please use that install and tell me if you have any luck with it.
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #6 on: October 12, 2008, 12:45:03 AM »
Nope, no joy with 3.042.014 either. Still dies during install.
« Reply #7 on: October 12, 2008, 09:12:49 AM »
Well.. that is the first time I have heard of that one..  I havea Vista machine here and I can install fine.. Please log on as admin and try to install.. That should help..
Brian
www.machsupport.com
« Reply #8 on: October 12, 2008, 01:16:34 PM »
There is only one account on my system and which of course is the administrator. I checked just to be sure and also tried to install yet again. It still hangs. I think I am going to download a registry tool to see if I have a corruption issue. Maybe one of the previous uninstalls didn't complete properly.
« Reply #9 on: October 12, 2008, 01:23:29 PM »
Hello,
Please try installing and unchecking the install Parallel port driver.. that should help.
Brian
www.machsupport.com
