Hello Guest it is October 21, 2026, 02:27:09 AM
Author Topic: Lithopane  (Read 116288 times)
Re: Lithopane
« Reply #40 on: October 29, 2008, 06:49:19 PM »
Both look nice fixittt.  I hate your bearing went out. How long did it take to machine them?
Re: Lithopane
« Reply #41 on: October 29, 2008, 09:38:52 PM »
They are all great and it's nice having experienced resources should i ever want to try it out.
Offline Kent
  •  34 34
Re: Lithopane
« Reply #42 on: October 29, 2008, 10:46:41 PM »
I hate when the machine hic-ups when doing a litho...  I have lost a few to z axis problems
Then I do something like drop one    :'(   I dropped my crucifix ...  So I cut another out of Arctic white , first was bone .
I did super clue the first  here's a pic of them side x side.. ... used the eagle to hide BBQ fix  :P
  •  9,374 9,374
Re: Lithopane
« Reply #43 on: October 30, 2008, 03:32:54 AM »
Another nice one Kent.
Best regards,
« Last Edit: October 30, 2008, 06:28:48 AM by Tweakie.CNC »
Re: Lithopane
« Reply #44 on: October 30, 2008, 07:50:46 AM »
I have about 2 hours worth of machine time in each.
I was wondering, what cutters do you guys use to do these?  I am still new to this and am looking for smaller size but good detail.  Any tips? Tricks ect?
  •  9,374 9,374
Re: Lithopane
« Reply #45 on: October 30, 2008, 08:11:39 AM »
The cutter I used to make the copy of Kent's wonderful white tiger is this one. It is solid carbide, single flute, reground ballnose shape, 3mm diameter. Not the smallest I have but it's a tough one.
Re: Lithopane
« Reply #46 on: October 30, 2008, 08:15:52 AM »
I'm not sure of the cutters my friend uses. I'll ask him. I know drastic reductions in machineing time can be had if you can stand to lower the res.
Offline Kent
  •  34 34
Re: Lithopane
« Reply #47 on: October 30, 2008, 08:49:17 AM »
I use 30 degree V bit  both .25 and .5 inch  I tell the software that they are 0.03 ballnose .Here is link to picture the other 2 bits are v90's
http://www.cnczone.com/forums/showpost.php?p=353705&postcount=140
I am able to make one pass .2-.23 deep with these bits ( BSimage from vectric site came up with one pass cutting with V bit)
I use these bits when ever I need high resolution. the portrait of my daughter was done with  .125 Ball nose .
Tweakie ( not my fence , I rent . and not going back to bubbles  ;D  lol  thanks for the laugh )
  •  9,374 9,374
Re: Lithopane
« Reply #48 on: October 31, 2008, 02:15:39 AM »
Hi Kent,
I deleted the bit about the fence because I thought that otherwise I would not be able to post anything again, unless I used bubbles.
Best regards,
Re: Lithopane
« Reply #49 on: November 04, 2008, 03:10:17 PM »
just got done with this one,  wish I had a smaller cutter I used the 1/16th ballnose endmill again.  Will work for a gift for my grandparents anniversary
