Hello Guest it is October 23, 2026, 09:54:56 PM
Author Topic: Modbus  (Read 22931 times)
Modbus
« on: June 19, 2006, 03:51:32 AM »
Hello,
To the development team: is there a possibility that in the future, Modbus/TCP will be implemented in MACH ?
Or is this not possible since a lot of functions in XP need to be shut down?
Greetz,
Kris.
Logic takes you from A to B, imagination takes you anywhere
Re: Modbus
« Reply #1 on: June 19, 2006, 06:12:46 AM »
TCP is on the list :) We are working on getting the Grex, USB, and a galil motion controlers up and running first :) .
www.newfangledsolutions.com
www.machsupport.com
Re: Modbus
« Reply #2 on: June 19, 2006, 06:27:30 AM »
Hello, 8)
Great! thanks.
I will be using WAGO-modules (german manufacturer). They have quite a nice range of fieldbus controllers where inputs, outputs, counters, pwm's etcetera can be  added modularly. and fair priced.
The fact that modbus/tcp will be supported is very interessting because i will then be able to only replace the serial controller with the tcp version (some reprogramming etc. offcourse). The serial modbus device i have now i will be using for another machine where serial modbus is the only solution. So that last machine will have t wait a bit for its expansion  :)
Is there any time frame you can tell me (not gonna nail you down on it) when this would be implemented? 6 months? a year ? more  :-\
thanks in advance and keep up the very good work you are doing.
Re: Modbus
« Reply #3 on: June 19, 2006, 08:03:37 AM »
I would think about a year or so... it could be less and I don't think it would be more.
www.machsupport.com
Re: Modbus
« Reply #4 on: June 19, 2006, 08:10:14 AM »
ok, thank
have another quaestion,
other topic so i'll post a new.
greetz
vytass
Re: Modbus
« Reply #5 on: June 28, 2006, 10:31:23 AM »
What kind of Galil DMC do you plan to use? PCI, RS232, USB or 10/100Base-T Ethernet. Or all? Or only I/O controller (IOC-7007 )?
It's a very  good news.
Will be #1 in testing ;-)
Re: Modbus
« Reply #6 on: June 28, 2006, 01:23:33 PM »
I am thinking about the 10/100Base-T Ethernet and the PCI :)
www.machsupport.com
Re: Modbus
« Reply #7 on: February 13, 2007, 10:32:52 AM »
Brian,
For Mach, will there be a difference between the pci and the ethernet Galil controllers?   I believe in general the difference is that the pci has faster communication and can handle interrupts faster.
Bill
Re: Modbus
« Reply #8 on: February 13, 2007, 09:53:23 PM »
Nope.... they will be the same
www.machsupport.com
