Hello Guest it is November 07, 2026, 12:43:09 PM
Author Topic: backlash  (Read 15936 times)
backlash
« on: June 18, 2006, 09:27:59 AM »
Hai All,
I am setting up a router with a servo drive.
The problem i am facing is that the gearbox of the servo motor is having a backlash of 2degrees on the gear end.
I want to use the gear box and do not plan to use a timing belt.
So I plan to install the encoder to the shaft of the gear box and not the motor spindle.
Will this cause any unnecessary hunting of the system.
I plan to use a higher count encoder so that accuracy is not compromised
Antony.
Re: backlash
« Reply #1 on: June 18, 2006, 10:41:19 AM »
You have to put the encoder on the motor. There is no way around it...
www.newfangledsolutions.com
www.machsupport.com
ynneb
Re: backlash
« Reply #2 on: June 18, 2006, 06:33:47 PM »
You have already introduced a serios comprimise, by using that gearbox.
One thing I have learnt about CNC is that you can have 90% good parts, but that 10% in bad parts, makes a 100% bad machine.
