Hello Guest it is November 22, 2026, 06:06:59 PM
Author Topic: No output from parallel port  (Read 38916 times)
Re: No output from parallel port
« Reply #10 on: September 27, 2008, 01:30:22 PM »
Install an i/o card in your PC and disable the onboard LPT in CMOS setup. i/o cards are cheap.
Joe
« Reply #11 on: September 27, 2008, 05:25:14 PM »
Your xml did not attach.
« Reply #12 on: September 28, 2008, 08:09:37 AM »
I think it is a driver problem. The ports and pins led's on the diagnostic screen do not change.  I cant seem to get the xml to attach. I sent it to Scott at support and he says there is no problem with it. What should the driver detail in the device manager be? My driver files show to be C:\WINDOWS\system32\DRIVERS\parport.sys provided by Microsoft.
« Reply #13 on: September 28, 2008, 08:52:15 AM »
sent you a PM
« Reply #14 on: September 28, 2008, 04:07:19 PM »
Have you got any printers installed on the computer? even if they are not connected.
« Reply #15 on: September 28, 2008, 07:06:40 PM »
No printers. I loaded XP Pro with no printer drivers installed.
« Reply #16 on: September 29, 2008, 02:54:55 AM »
Have you tried uninstalling the port from device manager and rebooting XP so that it rediscovers and reloads the drivers?
Offline Sage
  •  370 370
« Reply #17 on: September 29, 2008, 07:09:49 AM »
It is a printer port after all. Shut down Mach and try printing through it. That should test almost all of the signals.
Sage
« Reply #18 on: September 30, 2008, 04:04:40 PM »
Update time. I suspected a problem in my operating system since the pc had slowed way down and sometimes would not shutdown properly. I fomated and reloaded XP pro. I then downloaded Mach 3 and reloaded my xml file and liscense. Now my inputs are woking properly.  . My new breakout board came yesterday so I installed it. The dro's are working but I still have no outputs. The ports and pins current state shows no outputs.
« Reply #19 on: October 01, 2008, 04:27:47 PM »
disconect the PP cable and put a voltmeter on the Dir pin and a ground pin of the port and jog the axis one way then the other, if you see the voltage change 0-5v then the port is OK, if you dont then looks like the port is bad (assuming all settings are correct in Mach)
