Hello Guest it is November 22, 2026, 11:45:17 PM
Author Topic: Wizard suggestions -  (Read 77963 times)
Offline Psad
  •  82 82
« on: June 14, 2006, 10:49:14 AM »
Great work on the wizards.
Just finished watching the video and have a couple of suggestions.
On "rectangular Pocket"  you have "finish amount"  and "finish Feed Rate"  Why not add them to circular pocket wizard as well.
in the video that was a whole set of extra steps.  IF there is a tool change required it would still work as in the video.
On Circular Groove you call it "pitch" on other its called ramp angle.  Are they the same should they be called the same.
Sorry Just stupid things I noticed that caught me on the first look.
Re: Wizard suggestions -
« Reply #1 on: June 15, 2006, 10:19:40 AM »
That is a good idea to add that to the Circular pocket :)
Pitch is used because it is the amount that it is going to drop per pass around the part and the Ramp angle is the angle that it is going to go into the part..
www.newfangledsolutions.com
www.machsupport.com
