Hello Guest it is November 01, 2026, 10:25:27 PM
Author Topic: lic key  (Read 21340 times)
lic key
« on: September 19, 2008, 04:14:39 PM »
Hi guy's
I have a wizard button on my Mach 3 titled NFS when i click on it the menu comes saying i do not have a LIC for this when i purchased MACH and LC LIC's i thought that covered everything am I mistaken there is yet another lic i need ?
Rg's
Dennis
Re: lic key
« Reply #1 on: September 19, 2008, 04:20:31 PM »
If you have the licence called WizLic.dat you should have access to the NFS addons. Make sure it is in the Mach3 folder.
Re: lic key
« Reply #2 on: September 19, 2008, 04:31:25 PM »
A license is required for the "Newfangled" if listed under the Wizards pulldown menu / Function Name.
Re: lic key
« Reply #3 on: September 19, 2008, 04:31:50 PM »
Dennis,
There are 3 licenses.
RC
Re: lic key
« Reply #4 on: September 19, 2008, 05:14:41 PM »
So there is 3Lic's, OK is something new i didn't see that when i first purchased Mach3 otherwise i would have bought it to.
Dennis
Offline Kristin D
  •  203 203
  • Take that you LazyCam, next stop the glue factory!
Re: lic key
« Reply #5 on: September 19, 2008, 05:25:30 PM »
 ;D, Ka-Ching $$$$$$
Re: lic key
« Reply #6 on: September 19, 2008, 05:37:53 PM »
Been there all along. The site was changed a little bit a few months back but it was basically the same.
RC
Re: lic key
« Reply #7 on: September 19, 2008, 08:39:19 PM »
Dennis,
Here is a test you may want try to see if you want to spend some more $.
Just sketch something up and see if you can just use the wizards or maybe Lazycam ( Kristen can help you  ;D (couldn't resist Kristen :-*)
or whatever to do what you want. So your working manualy but also using the advanatages of wizards to do the hard stuff
( like milling a circle manualy). Then see if the add-ins will add to that and are worth the value for you.
Just some thoughts,
Re: lic key
« Reply #8 on: September 20, 2008, 10:58:19 AM »
Hi Guy's
 Thanks to all for the reply, it would be nice to use it on an eval to see if and how it works i am still waiting for LT to be fixed and working i just bought a LIC for D2nc I'll see how that works out first.
Dennis
Re: lic key
« Reply #9 on: September 20, 2008, 10:59:33 AM »
Just saw your side shot Kristin good one and about right.
Dennis
