Hello Guest it is October 04, 2026, 01:31:44 PM
Author Topic: Mainboard in CNC router control box  (Read 19175 times)
« on: September 18, 2008, 01:01:34 AM »
    I am new here and just finished my CNC router. This is working fine. However I have a question.
I have 4 Gecko G203V mounted on Alu plate, which is connected to 70 V power supply capacitor ground (neutral). Alu plate is mounted on control box enclosure, which is also connected to Mains Earth. This Earth is also connected to machine.
The BOB (C11G) is isolated in enclosure and only connected to PC trough parallel cable. The Earth of power supply of PC is also connected to mains Earth. All stepper power cables are sheilded and shielding tied up at one end on Alu plate and signal cable shieldings tied at BOB end only.
My question is can I place computer mainboard, Hard disk and SMPS in control box enclosure. Is there any grounding issue?
The enclosure is large enough to accomodate all these and a screen between MB and other items may also be provide.
I think I didn't made it complicated.
Thanks in advance.
Re: Mainboard in CNC router control box
« Reply #1 on: September 18, 2008, 01:38:35 AM »
I think you did it right.
I would also connect the shield of signal encoders to earth (alu plate)
« Reply #2 on: September 18, 2008, 02:26:23 AM »
OK what about my query?
« Reply #3 on: September 18, 2008, 02:45:57 AM »
->Is there any grounding issue?
I do not think so. You can use the same box if all metal is grounded (like a PC case).
Filipe
« Reply #4 on: September 18, 2008, 02:46:47 AM »
Filipe
Sorry, I meant:  "I think so"
« Reply #5 on: September 18, 2008, 12:56:33 PM »
THANKS
« Reply #6 on: September 18, 2008, 01:08:49 PM »
Both my mill and lathe have motherboards direct in the cabinet and no problems with them.
