Hello Guest it is November 24, 2026, 11:15:11 AM
Author Topic: PWM questions for CO2 Laser  (Read 38332 times)
Re: PWM questions for CO2 Laser
« Reply #10 on: September 16, 2008, 07:01:10 PM »
No that is probably the driver test that is included with the lockdown version which I presume you are using. Try the special driver, you will find it in the Mach 3 folder, just double click on it and then try the drivertest again.
DaveDoesIT
« Reply #11 on: September 16, 2008, 07:23:53 PM »
Thanks Hood, but...
Just did that and ran the drivertest and it said, "installed, reboot" I rebooted.
I ran drivertest and when it "took over" I get nothing in the output window.
I ran Mach3 and set the spindle to PWM and now the Base freq is staying at 5000, so that's some sort of progress.
I have checked the Help pdf and that has not helped. This is an new computer with 2.4G core 2 duo, 2G memory, award BIOS and APIC shows as detected in the test. I am using win2000 Pro.
« Reply #12 on: September 16, 2008, 07:26:01 PM »
Have a look in device manager and see if the pulse engine is installed there.
DaveDoesIT
« Reply #13 on: September 16, 2008, 07:29:32 PM »
To make matters worse, when I clicked Exit from the dead drivertest,it is still attached to something as I am getting a serieds of momentary delays in windows minimizing. I will have to reboot damn it.
It takes about two seconds and 20 jumps to minimize any window.
GGrrrr.
DaveDoesIT
« Reply #14 on: September 16, 2008, 07:56:37 PM »
This what you mean?
Don't you ever sleep?
« Reply #15 on: September 16, 2008, 08:06:15 PM »
Yep and nope but I am just going ;D
Well certainly seems like its installed, just for kicks try double clicking the normal driver (in Mach3 folder again) and see if it works this time.
DaveDoesIT
« Reply #16 on: September 16, 2008, 08:26:34 PM »
Nope, same ol same ol.
Beer and dinner time for me. I will attack it again ion the morning.
Thanks for the help so far.
