Hello Guest it is November 22, 2026, 01:07:37 AM
Author Topic: Configure the Mach3 for Proxxon MF70  (Read 14270 times)
« on: September 07, 2008, 04:43:47 AM »
Hello guys,
I am a newbie into the cnc and I started when I buying a Proxxon milling machine MF70.
Also I got from www.cnc-plus.de 3 stepper motors and the controller.
http://www.cnc-plus.de/product_info.php?info=p137_3-axis--2-5-Amp-Step-Motor-Driver-AMW-102.html
I have problems to set with the appropriate values the motor tuning tub.
More specifically
I am using the step resolution per unit at 1600 according the controller manual and
I set the velocity at 5,8 and accuracy 6,5.
I test it with g-code commands and I also observe that I have a loss in about 0.1mm
Has anyone works the MF70 and mach3?
Any suggestions?
