Hello
Guest
it is
October 24, 2026, 04:06:16 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
Newfangled Solutions Mach3 Wizards
(Moderator:
Ron Ginger
V2.79
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: V2.79 (Read 56252 times)
TDAY
165
Re: V2.79
Reply #10 on:
November 18, 2008, 11:09:07 AM »
In the Cut Rectangle there looks like there is a DRO under the depth DRO.
Also the preview does not show the correct amount of passes.But it does show the correct amount of passes in the Mach3 display.
And when doing an inside cut, the selection of a Climb or Conventional cut is backwards.
Do i have a setting wrong?
Troy
Last Edit: November 18, 2008, 11:53:51 AM by TDAY
Logged
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Ron Ginger
925
Re: V2.79
Reply #11 on:
November 18, 2008, 04:26:41 PM »
Sorry, I dont know what you mean by "there looks like there is a DRO under the depth DRO."
I will check the other issues, There have been other cases where the preview codes did not exactly match the post code. Ill see what I can find.
Logged
TDAY
165
Re: V2.79
Reply #12 on:
November 19, 2008, 06:02:34 AM »
The 2 depth DROs must have been a glitch in screens,because it has went away.
Troy
Logged
Print
Pages:
1
2
Go Up
« previous
next »
