Hello Guest it is October 22, 2026, 04:12:04 PM
Author Topic: Homing Probem  (Read 28787 times)
Re: Homing Probem
« Reply #10 on: August 28, 2008, 04:22:26 PM »
    I have a question / problem with homing. My machine hits the home switch at 24.1 inches. In my homing script the machine homes and sets the X dro to zero then
moves -.1 to get clear of the switch . I am having trouble setting the DRO to 24.00 Inches which is where the machine is. I would like this to happen automatically.
I am running Mach2
Any help would be appreciated !!!
Sean
Re: Homing Probem
« Reply #11 on: August 28, 2008, 04:26:59 PM »
Not sure in Mach2 as its been a long time since I used it. If you can find a Home Off box then that is where you put the distance you want. In Mach3 its under Config menu then Homing and Limits.
Re: Homing Probem
« Reply #12 on: August 28, 2008, 07:36:16 PM »
    Thanks !!!  That's exactly what I was looking for.
Sean
