Hello Guest it is October 31, 2026, 03:13:58 PM
Author Topic: why does mach not let me do this on MDI  (Read 32661 times)
Offline josh
  •  101 101
« on: August 16, 2008, 11:34:34 PM »
hi how is everyone doing.
I got this little problem with mach hopefully someone can tell me whats wrong?
I started mach loaded a program ran good. but then when I went into MDI for some reason
it will not let me type certain letters and numbers like I try to type M06 T1 and it would not
input nothing but if I type some other letter it would.
can some tell if I have modify something.
thanks
Re: why does mach not let me do this on MDI
« Reply #1 on: August 17, 2008, 04:21:52 AM »
First off is this Mill or Turn? Second are you sure you typed a Zero and not the letter O?
Offline josh
  •  101 101
« Reply #2 on: August 17, 2008, 04:21:45 PM »
yup it is a mill
and yup I am typing the number 0
O by the way I have 2 mach mill set up on my desktop one with a keygraber set up and the other one with out it
the one that does not have the keygraber setup it works fine but I would like to use the one with the keygraber
I hope that makes some kind of sence.
thanks.
« Reply #3 on: August 17, 2008, 04:39:35 PM »
What are you using Keygrabber with? What is the difference beween the two screens if any? Can you use KeyGrabber with the other profile to see if it changes things?
Offline josh
  •  101 101
« Reply #4 on: August 17, 2008, 10:05:45 PM »
I am using keygrabber with a gamepad like the x-box ones it has a usb coard at one end
and nope there is no differrnce in the screens. I still cant get it to work
i shall keep trying if some one has the same problem please let me knowhow you fixed it
thanks for the replys
« Reply #5 on: August 17, 2008, 10:22:47 PM »
Josh, have you modified your screen set? If so, post it and I'll have a look. If not, post your xml of the profile your having trouble with.
Offline josh
  •  101 101
« Reply #6 on: August 18, 2008, 12:04:09 AM »
I wish i was a little more experience in this but I have no idea of how to post my screen set. or even my xml file.
all this is computer stuff is pretty knew to me.
« Reply #7 on: August 18, 2008, 12:47:12 AM »
No worries Josh, its easy to do. At the top of this reply there is a tab, reply. It takes you to the full reply page that is a little different than the quick reply at the bottom.  Once you clcik it you'll see the reply box and the words additional options listed just to the left below the box. Click on it and browse to you C:\Mach 3 folder. There you will find your screen set. I don't know if you have a custom or not but by your problems I think maybe you do. It will have the .set extension on it. If it is the default 1024.set you'll have to rename it before posting it.
Hope this helps,
Offline josh
  •  101 101
« Reply #8 on: August 18, 2008, 01:52:28 AM »
hopefully this is the right way o do but here it is
Offline josh
  •  101 101
« Reply #9 on: August 18, 2008, 01:56:44 AM »
hol?? sh?t ,I did it
thanks brett for going through all that trouble on guiding a step by step.
I think this might what your looking for
